starter failing?
/ starter failing? #1
PoppaRob
ma
MF gc2310tlb
I am not a mechanic, and am taking a guess that my starter is failing. I have a Massey Fergusson gc2310 (sub compact) that occasionally when i turn the key it sounds like it's gonna start but then i get a sigh (like air escaping) and a click and it stops. turning the key again 90% of the time it will start. is this a sign of the start failing or is there something else i should try first?
Thanks!
/ starter failing? #2
It may be a sign of starter failure. It's possible it's not spinning up fast enough or with enough force to engage the pinion with the flywheel. You could also have a Bendix problem but generally the starter and Bendix come as a unit when you buy a starter. I'd start by being sure of the battery condition then clean and tighten the terminals as well as the battery's frame ground. If power to the starter is marginal that can seem like a weak starter.
/ starter failing?
OK, Thank you for that. Battery and connections first, starter second and whatever a bendix is, third.
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
MF GC2300 fel replaced
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
