Start sometime
/ Start sometime #1
Shanet
Ford 1720
Hello we have a kioti 40hp. Ds4110HS. Sometimes it will start with key and sometimes it want. You can turn key on when it don't and cross the starter out an start it. Help ? I already check the seat switch.
/ Start sometime #2
Check the owners manual. On my DK55, the PTO switch must be in the off position to start.
/ Start sometime #3
I'll go along with Jim on the owner's manual. The newer tractors have several safeties built in which must be satisfied. There is the seat switch and the PTO switch of course but there may also be a clutch switch, a neutral switch, and a sensor on the HST engagement (if the tractor is HST). If safeties are not satisfied the starter will not go,
/ Start sometime #5
I'll go stand in the Bad Ignition switch line !
/ Start sometime #6
I cleaned AND replaced the key switch, with minimal improvement. In my case changing the relays cleared up my issues. However, I guess start with cheapest/easiest first….
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2007 Chevrolet C7500 Auto Crane 8406H 8,400 lb. Crane Mechanics Truck (A66736)
2007 Chevrolet...
CASE CX60C EXCAVATOR (A65056)
CASE CX60C...
PALLET OF MISC ITEMS (A67714)
PALLET OF MISC...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
