Start sometime
/ Start sometime #1
Shanet
Ford 1720
Hello we have a kioti 40hp. Ds4110HS. Sometimes it will start with key and sometimes it want. You can turn key on when it don't and cross the starter out an start it. Help ? I already check the seat switch.
/ Start sometime #2
Check the owners manual. On my DK55, the PTO switch must be in the off position to start.
/ Start sometime #3
I'll go along with Jim on the owner's manual. The newer tractors have several safeties built in which must be satisfied. There is the seat switch and the PTO switch of course but there may also be a clutch switch, a neutral switch, and a sensor on the HST engagement (if the tractor is HST). If safeties are not satisfied the starter will not go,
/ Start sometime #5
I'll go stand in the Bad Ignition switch line !
/ Start sometime #6
I cleaned AND replaced the key switch, with minimal improvement. In my case changing the relays cleared up my issues. However, I guess start with cheapest/easiest first….
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
1998 TRAIL KING TK70HT HYDRAULIC TAIL TRAILER (A67714)
1998 TRAIL KING...
2018 Mazda 6 Sedan (A66738)
2018 Mazda 6 Sedan...
CAT 345CL NEW Track Chains (A68134)
CAT 345CL NEW...
2006 Ford F-350 Crew Cab MOT Safety Truck (A66736)
2006 Ford F-350...
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
