START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #1
Brimfield
Mass
Kubota L 3800
I have a homemade chicken plucker that I built a few years ago I used a Marathon 3/4 hp farm duty motor from Tractor Supply. While moving firewood last winter the motor got hit and the start capacitor came off. There are 2 black wires from the motor, one is brass colored the other is silver. The brass terminal has J9 on the wire and the silver has T5. I see this on the wire diagram I have but I do not know if it makes a difference what side goes on where. There are 2 sides so does it matter what side they are on. I know they need to go on separate terminals
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #2
Doesn't matter, wire markers are basically where they come from.
That is what I was thinking but I was not sure on that. I just expected that there was a specific way the wires had to go on.
Thanks
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #4
Those capacitors are non-polarized and are being used for A/C current, so it doesn't matter.
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #5
Does not matter. If the capacitor is damaged, install a new cap with a voltage rating as high or higher than the original. The microfarad rating can also be increased, this will improve starting torque.
Thanks guys! It has no problem starting so If I broke the capacitor I'll get a replacement.
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #7
It looks like that one may be leaking out oil any way, good reason the replace. They are not really made to get; the metal ring holding the case on is thin and rusts quickly.
Ron
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
377811 (A48836)
377811 (A48836)
Ingersoll Rand TS5 80 Gallon Air Compressor (A51573)
Ingersoll Rand TS5...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
