START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #1
Brimfield
Mass
Kubota L 3800
I have a homemade chicken plucker that I built a few years ago I used a Marathon 3/4 hp farm duty motor from Tractor Supply. While moving firewood last winter the motor got hit and the start capacitor came off. There are 2 black wires from the motor, one is brass colored the other is silver. The brass terminal has J9 on the wire and the silver has T5. I see this on the wire diagram I have but I do not know if it makes a difference what side goes on where. There are 2 sides so does it matter what side they are on. I know they need to go on separate terminals
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #2
Doesn't matter, wire markers are basically where they come from.
That is what I was thinking but I was not sure on that. I just expected that there was a specific way the wires had to go on.
Thanks
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #4
Those capacitors are non-polarized and are being used for A/C current, so it doesn't matter.
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #5
Does not matter. If the capacitor is damaged, install a new cap with a voltage rating as high or higher than the original. The microfarad rating can also be increased, this will improve starting torque.
Thanks guys! It has no problem starting so If I broke the capacitor I'll get a replacement.
   / START CAPACITOR WIRE QUESTION FARM DUTY 3/4 HP MOTOR #7
It looks like that one may be leaking out oil any way, good reason the replace. They are not really made to get; the metal ring holding the case on is thin and rusts quickly.
Ron
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2023 John Deere S780 Combine (A53342)
2023 John Deere...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
