Starlink
/ Starlink #2,041
I just installed my dish and I've got to say, I was super duper totally excited to drill two 1 inch holes through the brick to fit the molded connector. I've installed things like this my entire life and that they consider this a self-install kit is surprising.
If you disconnect the cable from the antenna all you need is a 1/2" hole,
is does disconnect when a good straight pull.
/ Starlink #2,043
Does that apply to the new dish? It did not appear to be able to disconnect hopefully I'm wrong
/ Starlink #2,044
Are you speaking about the new dish or the old (round) style?
/ Starlink #2,045
The new rectangular dish the cable will disconect
/ Starlink #2,046
It does take more of a pull then feels comfortable, I actually contacted tech services about mine as I couldn't see how that big L shaped connector would fit through a decent sized hole.
/ Starlink #2,049
/ Starlink #2,052
Dumped DSL and went with Verizon 4G LTE internet 3 months ago. Worked well for the first 2 months with 40+ down and 8+ up 24/7. now however, it drops to 8 down & 1.5 up during peak times in the evening and especially on weekends.
Anyone else notice this?
I may go with Starlink after all if my number ever comes up.
/ Starlink #2,053
My Verizon 4G LTE has been pretty steady. Starts at 60-70 for download and then throttles back to 50. It will slow down to 30 in the evenings sometimes.
/ Starlink #2,055
that's going to be different per Cell tower.
/ Starlink #2,056
True but it makes me wonder how slow it will get as Verizon adds more customers per tower.
The same will likely happen with Starlink over time but I doubt it would ever get as slow as the 4G LTE service.
/ Starlink #2,057
They prolly have a limit, I have read this before, that they will block people similar to what starlink does.
/ Starlink #2,058
I just sent a support request to StarLink. Infrequent outages began on Saturday but not too bad. Last night it became unusable. Up until now the service has been great (3 weeks in). I haven’t changed anything or moved the dish. No obstructions. The dish is flipping around and scaring the squirrels.:sneaky:
/ Starlink #2,059
4G LTE internet 3 months ago. Worked well for the first 2 months with 40+ down and 8+ up 24/7. now however, it drops to 8 down & 1.5 up during peak times in the evening.
We used 4G from a local guy (private labeled from T-mobile) for 3 years and decent results. It started to get annoyingly slow during peak times about three months ago.
We just put in a microwave link which has been great -25 M / 35 ms ping- (except in an ice storm).
I put in for Starlink last February but may give up my slot which is coming this month.
/ Starlink #2,060
Mine went flakey for half a day contacted support they are supposedly sending a replacement unit out.
I did a quick 5 second power off and back on 5 minutes later it was up and normal.
Prior to that they had asked me to do the rapid 3 times power off/on which resets everything to factory defaults,
and updates the operating software which didn't seem to do much.
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A64553)
JMR 78in Dual...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
3 Point Hay Tedder (A65640)
3 Point Hay Tedder...
Husqvarna MZ61 Zero Turn (ZTR) Mower (A66285)
Husqvarna MZ61...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
