Starlink
/ Starlink #4,101
I have the Deco M9+ system. Has worked great for our wifi in our house. Three mesh nodes, one hard-wired to the network where SL lives, the other two wirelessly linked. Made a huge difference in signal strength throughout the house. If anyone has wifi signal issues I highly recommend a mesh system and the Decos are good ones.
/ Starlink #4,102
I've had SL for a few years now and its worked perfectly fine for us. We have zero cell phone reception so all calls for us come and go via SL. I have a few services that require a cabled connection so I added the ethernet adapter and an old switch to support their connection which is the only thing added other than what came in the box. When I set the system up the best place for the SL router/WiFi has on a window sill. 90' away from that window is my shop - a metal pole structure. Once inside the WiFi drops substantially but a text will still make it while inside the shop. So I've thought about adding a repeater. Any suggestions? There are so many devices so I'm asking here what you use and would recommend in terms of IP voice/text support vs price. for the repeater while in the shop?
If I like it I may add the same in the opposite direction for the barn and animal pens. I do have power at the shop and the opposite direction by the barn. Of note, the only reason I haven't done a 'mesh' is that we live in a heavily treed area and I am done with trenching through tree roots and laying conduit to get power to remote devices. I will not mess with anything battery powered so I'll stay with locations where the power is already in place.
/ Starlink #4,103
Any of the outdoor rated ones (TP-link, etc.) will pull in the signal, and can be cabled to a second one inside. However, although it is pricier, I would serious consider using a POE switch in the shop wired to an outdoor access point to pick up the house, and a wired indoor access point to cover the shop/barn. If you get a managed switch, you will be able to easily check on the system(s) from the house. If you have a long run to the house, you might be happier with point to point connections,Lao called building bridges, rather than trying to stretch the house WiFi signal.
I think it depends on your budget and how much signal and bandwidth you want in the outbuildings.
All the best,
Peter
/ Starlink #4,104
Don't use a repeater. They cut the bandwidth in half due to their design. Look into a wireless bridge. As long as you have line of sight between the buildings they can work for miles. They aren't that expensive either. That's how I get wifi to my metal pole barn which is 200' from the house. And I don't even have them fixed mounted... just propped in windows on each building generally aiming in the direction of the other.
/ Starlink #4,105
As I’ve said I’ve been pleased with StarLink for over 2 years now. ,,,, But I got a call from the local Verizon store yesterday asking if I was pleased with my cell service ( ie. Fishing for me to upgrade 🙄) I took the opportunity to ask if wireless home internet was available yet for me. After a little digging he said yes as they were just beginning to roll it out in my area. $40-$60 a month with no data limits. Huh. 🤔 I’m going to need to reevaluate $120/month Star Link at some point.
/ Starlink #4,106
My wife uses Verizon Wifi and it suks compared to my ATT&T or Starlink. Of course it depends upon the quality and capacity of the cell service in your area.
I think you get what you pay for.
/ Starlink #4,107
Spectrum just laid fiber down the road along the front of our property. They are coming out today to connect 300mbps for $49.99/mo to the house, plus $14.99/mo for a landline. Next Wednesday they are connecting 100mbps for $29.99/mo to the shop, plus a landline. That will be our phone for the stained-glass business. It will lower my current landline & internet cost by $55 a month plus giving us a separate phone line for the shop.
/ Starlink #4,108
What you can do when people have limited options :(
/ Starlink #4,110
I just got my Starlink equipment yesterday. I'll set it up this morning.
Quick question on the phone app. Can it be controlled/monitored from multiple phones? The Starlink is in my name, but I travel a bunch, and my wife might need to check it too, when I'm away. Can we both download the app and have access?
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Chevy Malibu Sedan (A59231)
2014 Chevy Malibu...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
