Starlink
/ Starlink #4,091
This is the new gen 3 router Starlink is offering:
I bet their website shows much more info in its specifications.
I have the original starlink router with cat cables running to
(Unifi) wireless access points to upstairs/ downstairs and 2 detached garages. I had this equipment on-hand. Overkill, I know
(Good coverage and I have not purchased this new router.)
This was the email I got :
"The new Gen 3 router introduces WiFi 6 and tri-band radios to Starlink.
With improved range, performance, and device support, the Starlink Gen 3 router will extend your WiFi network throughout your home to provide a more consistent and reliable connection.
How it works
The Gen 3 router is a drop in replacement for your current router and will arrive with everything you need to get connected to your current Starlink. If you purchase multiple Gen 3 routers they can be meshed together to extend the range of your WiFi network. "
regards,
R
/ Starlink #4,092
FWIW:
In case any of you are considering mounting your Starlink router outdoors, Altelix has introduced a line of outdoor, waterproof resistant, fan cooled enclosures specifically for Starlink.
I made something similar for mine, and it was really helpful to us for maximizing the Starlink WiFi signals.
All the best,
Peter
/ Starlink #4,093
I just ordered Starlink today. I used to have a LOS radio internet that transmitted from my attic, to a repeater on a neighbors barn, that just became super slow as they added subscribers and it wasn't reliable. So, I changed to an AT&T brick, which is also slow and requires frequent reboot's. With my wife looking for a "work remote" job, I need to at least be able to attend and host a microsoft teams meeting. I could barely even stream with the old set-ups.
So, help bring a network challenged newbie up to speed with what else I need.
I ordered the basic service with a pivot mount. I want to wirelessly cover my home and patio. I assume this Starlink thing then gets hooked up to a wireless router to cover the house. What's the best router to get? The one I have laying around from my radio internet was a 2.4/5.0, but it's at least 5 years old. I assume there's something better out there now. My house is a 2300 SF 1-story brick with a large outdoor covered patio. If I could also cover a 600sf in-law apartment that's 50' from the main house, that would be a bonus.
Edit:
If this Starlink now gives us reasonable speed to stream, I'd like to dump our Direct TV satellite and use a streaming service. Any recommendations for that?
As ponytug & Bigblue posted, everything you need may be in the box. A decent wifi router and cabling is included. First find an unobstructed sky view using the phone app for the dish then it’s hopefully plug and play. I suggest trying out a temporary setup at first. I put the dish on a picnic table and ran the cable through a window to the router.
For TV streaming I first tried HULU (😣) and am currently using YouTubeTV. Pretty similar in channels offered and cost per month at around $75. If HULU still has issues with StarLink’s location verification I would avoid it.
/ Starlink #4,094
The new router is not worth the upgrade in our case. I run the ethernet into the house from the Shop (taller building) and use a Wifi6 router off of that. The Starlink router gets us signal in and around the shop while passing the signal into the house.
Wifi6 is worth it if you need more speed.
/ Starlink #4,095
We use Hulu and I've not had location issues like I have seen in the past with YouTube. The YT location issue can be solved simply by logging into the YT TV account on your phone's browser and going to a particular place in your account to allow YT to let them access your actual location (versus what your ISP shows). I'd assume Hulu must have something like that.
/ Starlink #4,096
/ Starlink #4,099
Edit:
We have been using Starlink for several years for Internet access including streaming videos, normal access, and web conferencing. Starlink has worked just fine even with my wife and I on separate web conferences at the same time.
We can have multiple video streams going as well.
We have the second generation dish and the router sits in the center of the house. The performance was not bad but we bought a couple of Starlink mesh extenders to improve the data rate at the "ends" of the house. They were easy to setup.
There have only been a few Starlink outages, the longest was 45 minutes or so. HEAVY rain can disrupt the signal but we had that problem with cable and cell internet too.
Starlink is simply a game changer for those in remote areas. I just watched a video of a woman travel to a remote Scotish island, and she was worried about Internet access, so she took her Starlink setup with her. The cell access was good, so she did not have to setup Starlink, but she could have if needed. Science Fiction that is.
/ Starlink #4,100
I put starlink in bypass mode and installed Deco mesh system, best thing I ever did.
I do the same -- the decos are hard-wired and everything else in the house is wireless/connects to the Decos. Works great.
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2014 GMC Savana 3500 Cargo Van (A59230)
2014 GMC Savana...
Volvo ECR235CL (A53317)
Volvo ECR235CL...
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
