Starlink
/ Starlink #3,741
78.5 down and 18.3 up
Not bad for a Friday evening around here.
/ Starlink #3,742
Normal test was 46/10. Then advance test gives the above.
/ Starlink #3,744
I’ve been getting poor signal to mesh node errors lately. I haven’t moved anything.
/ Starlink #3,745
My speed tests looks ok, but today everything is dragging online.
/ Starlink #3,747
What is an acceptable per cent of obstructions to get on the ap and still have decent service. My test locations are best .71 to 2.65 will that be good enough?
/ Starlink #3,748
.71 is good enough for most everything, you might maybe have a few issues with the 2.65 if you are using it for video calls. Most streaming services will buffer thru the 2.65. For email and web surfing, what you have listed won't be noticed.
/ Starlink #3,749
First bear in mind that the app maps obstructions optically with a camera, and Dishy will use high frequency RF. So Dishy may be more affected by a guy wire in the line of sight, or a metal roof just below the sight line.
It depends on what you want to use it for. Things like gaming are very sensitive to obstructions, but YouTube and video calls buffer so it isn't as much of an issue, and if you are browsing the web, you probably won't notice it much at all.
But it also matters whether the obstructions are small, many, and close to the horizon, or whether you have some big pole that causes the obstructions. One big obstruction that is tall causes a longer duration impact than scattered ones.
As Starlink gets more satellites up, obstructions should matter less, and to the extent Dishy can learn your obstructions, and switch to avoid them, it may have less of an impact.
Does that help?
All the best,
Peter
/ Starlink #3,750
My main obstructions are tall trees to the north and west, we are in a valley on the north slope. I do not do gaming and most of our use is surfing and video calls
/ Starlink #3,751
Based on our experience here, my guess is that it won't make much of a difference to your uses.
When you did your scan, were you holding the phone at the exact height and location that you plan to install it? Small differences in height and location can make a big difference. With trees at the horizon, small changes in height can make a big difference.
FWIW: With our site, I had some tree obstructions as well (similar site to yours), and I ended up moving Dishy 250' or so eastward to reduce the impact of the trees. I was going for zero obstructions as this was early in the non-beta phase, and coverage at our latitudes was thin. With all of the extra satellites on station, I'm not sure that it would be worth doing now.
All the best,
Peter
/ Starlink #3,752
I have no obstructions but have had issues 3 days now. Mesh won’t connect to router, poor signal standing anywhere including next to the router. I have restarted all. I have unpaired and re paired the mesh. System is on UPS power.
So far support has said reboot everything. Looks to be a router issue. And the app is now different, they keep changing it.
/ Starlink #3,753
Starlink closed my ticket and said it was network congestion. But the issue I reported was a weak WiFi signal that couldn’t keep any devices connected, including the mesh unit. Getting under 50% signal next to the router.
They also said they did SW update to my unit, which did fix the problem, sort of. Still not good signal strength but it’s not dropping out, and the mesh now works.
/ Starlink #3,754
Have you looked in the advanced debug section of the settings to see what the WiFi and network items look like?
How close is your nearest neighbor? Any chance of a WiFi spillover from there?
Bad WiFi can come from lots of things, not just the router. Is it possible to power down everything in your house except for Starlink (including your laptops) and see what your phone thinks next to the Starlink router? Then turn on just the mesh, and check at the mesh and at the base Starlink router again? And then power up more of the house?
Good luck.
All the best,
Peter
/ Starlink #3,755
One of my brothers installed Starlink a few weeks ago and so far he has been very happy with it.
/ Starlink #3,756
Good luck.
All the best,
Peter
Under Settings - Advance, only options are:
Custom DNS
Bypass Mode
Factory Reset
/ Starlink #3,757
Custom DNS
Bypass Mode
Factory Reset
Sorry for the bad directions.
Try at the bottom of the main page "Advanced", then "Debug". Things had moved around since the last time I had used the app. To me, the new version does look easier for new users.
All the best, Peter
/ Starlink #3,758
Got my Starlink Friday and got it set up. Speed is all over the place from 5 to 189 mps. Shows unobstructed view. What should you use for speed test. Plain speed test or advanced speed test on Starlink .
/ Starlink #3,759
I always run the Starlink advanced test because it lets me parse out how Dishy to the ground station (via the Starlink router) is doing, and to have some data on the Starlink router to the rest of my network as separate pieces. If there is an issue, I dig into the outages (especially the sub 0.5 second ones), and the advanced debug statistics.
The trouble with other speed tests is that they measure from your phone/tablet/PC via the Starlink ground station to some site that is "nearby" to where the test site thinks your Starlink ground station is, which may or may not be accurate. Right now sites that are guessing my ground station location are off by a good 1,000 miles, and neither is close to my actual location.
I would give your setup a few days to settle in and allow Dishy and the router to get their local ducks in a row with regard to local obstructions, and best network settings.
All the best,
Peter
/ Starlink #3,760
Having trouble with my mesh unit continuously dropping out, so I unpaired it for now. Router been working ok without the mesh.
Aluminum Hog (A65583)
(2) 10ft Nesting Boxes (A65579)
(2) 10ft Nesting...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2007 VERMEER T755 COMMANDER III TRENCHER (A65643)
2007 VERMEER T755...
2019 CENTEX TRAILER 16' COOL DOWN TRAILER (A65643)
2019 CENTEX...
