Starlink
/ Starlink #4,732
I don't doubt SpaceX will be huge )already is). Unfortunately the little guy can't get in until SpaceX goes public. Then it'll be much more difficult to make any money.
Do you say that because SpaceX is so widely known and successful prior to going public? I sure wish I had about $100 worth of Nvidia when it went public, that would be worth close to 500 thousand now.
/ Starlink #4,733
So you'll be buying $100 of SpaceX then. :sneaky:
Any more hot tips?
/ Starlink #4,734
Got our "free" Starlink Mini in the other day & got to play with it a bit today. Set it out on the back deck table & ran it from a 30v supply powered by a 30AH 12v Lifepo4 battery. (I took advantage of the nice weather to also test a new folding 100W solar panel).
I let it run for a bit, then did the setup. Took no time at all doing it from the phone. A firmware update was queued so I let that run.
It's on the $5/mo "standby" plan, but still has internet connectivity (at slow speed).
Slow speed, but better than 3 times the speed we considered "fast" dialup back in the dinosaur days. 1/2 price roaming plans are available for occasions when we might need to use it for more typical operations.
Also got a chance to check how well an Apache 3800 case (Harbor Freight) might do for portable use. I printed some clips & attached them to the underside of the case lid with 3M VHB tape.
It fits pretty well. Plenty of room left for the battery in the top pic plus extras. Once things are together I'll try out operation while inside the case.
/ Starlink #4,735
I have a question , I have had starlink now for over a year and lately it is listing my location as Virginia even though I live in Pennsylvania. Is there any thing I can do to change my location.
/ Starlink #4,736
Good luck, my location always comes up as NYC so any search is centered around that damned hole.
/ Starlink #4,737
Sorry to say NO. Your location is dependent on which Starlink ground station you are connected to and where that ground station connects to the internet. I live in VA and my location has moved from GA to NY to VA to CA, presently it shows me in Ashburn VA.
/ Starlink #4,738
I think what you mean to say is not "Starlink is listing my position as ..." but, rather, "Online services I interact with are interpreting my location as ...'
Some services, often streaming media services or shopping web sites, will try to interpret your physical location based on the IP you're connecting to the Internet with. In Starlink's situation, the ground station or datacenter where the sats you connect to actually interface with and connect to the Internet from may be dozens or hundreds of miles from your physical location. There is zero you can do about this. It is just the nature of the networking involved. This has been true with any ISP for a long time. I live in central MN but when I was using AT&T for Internet everything thought I was in Chicago.
Any service that enforces rules based on location, primarily streaming media services, typically has a method to verify your location in another way. For instance, with YouTube TV they will have you go to a web site on your phone and give your browser temporary phone location permission to verify where you're actually at. Contact those companies and ask for how to deal with the situation. For online shopping sites that try to find "closest store" I don't think there is any way to fix that.
/ Starlink #4,739
Nice summary of the issue. I know where "my" Starlink ground stations are here in Northern California, but the outside point of presence is usually Los Angeles, but not always. As you write, it depends on routing.
I buy from a chain that defaults to believing I'm 3,000 miles away. It always makes me smile.
All the best,
Peter
/ Starlink #4,740
For those that have all the speed and latency discussions, earlier today and probably tomorrow through the weekend are probably stompin' mad days. Repeat next week.
Here, now, you're home, like everybody else, and your gaming while watching sports is REALLY frustratingly slow and the TV keeps buffering.
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
