Starlink
/ Starlink #3,721
I could show you my bank statement where they have billed me the $150 monthly service, and I could show you the FedEx tracking that shows my equipment has not left the facility.
I totally agree that it doesn’t make any sense. That’s why I find this experience so frustrating. I have sent 3 messages over the last 3 days, each time I get a canned response that basically says they’ll get to me when they get to me.
So this initial customer service experience is turning me off to the entire thing.
That's why I was telling you about the phone thing. I asked them a question through the app and was expecting a response through the app but they called me instead.
/ Starlink #3,722
I cannot get regular service until 'sometime in 2023', but I can get high priority service right away. $2500 for hardware plus $250 a month. I guess I will have to wait.
/ Starlink #3,723
@Fishin-4-a-Livin That sounds frustrating and annoying. It also sounds like a screw up on their end. As @BigBlue1 pointed out the billing normally doesn’t start until your equipment is configured. Keep sending in the ticket requests.
All the best, Peter
/ Starlink #3,724
I'm not disputing that it is happening to you. Just saying that the situation is not normal to let you know that you should most definitely keep contacting them to have them fix it and refund you for the unusable service charges.
/ Starlink #3,725
The $2,500 and $250 a month sounds like the Maritime package which is for vessels moving across oceans. Interesting that the Maritime service is available now. Many people doing coastal boating are using the regular dish without issues. Some vessels crossing oceans are using the regular dish and service, which is not supported, but seems to work as long as vessel speed is below 10 knots. Sounds like not many people are buying the $2,500 package. :unsure:
/ Starlink #3,726
Not anymore they aren't. SL has begun cracking down on stationary dishes used in proximity to waterways and in motion.
/ Starlink #3,727
All the best, Peter
They finally responded by email and have refunded the $150 monthly fee and apologized for the crappy customer service.
Hopefully they send my stuff soon.
/ Starlink #3,728
I follow two different boat forums, one is mostly US while the other has quite a bit of coverage overseas. There have been some reports of StarLink going after stationary dishes on boats but most people are still working without issues. One key limit seems to be speed. If one is going over 10 knots, then there might be a problem.
People are using the stationary dish on thousand and thousands of sail boats and trawlers around the world. The biggest issue has been the frequents changes in price and terms of agreement.
The last Star Link update I saw was that as long as one was in coastal waters the stationary dish would work. Would it work while moving seems to be an issue of the speed of the boat. Having said that, people crossing oceans are using the stationary dish, but they are not moving fast.
/ Starlink #3,729
I used the app to scan the sky to find a location, once my equipment does arrive.
The best I can get is about 10% obstructed view. It‘s scattered treetops that are blocking.
Wonder how much of an issue that will be?
/ Starlink #3,730
That will most likely cause short, intermittent outages. However, if you mount the antenna higher than you were holding you phone, the results will differ. Higher would be better, if you can mange it. I put mine on an outbuilding to get out of the trees.
All the best,
Peter
/ Starlink #3,731
It will definitely be noticeable. Unobstructed view is vital for the dish to track the sats as they come into view and work their way across the sky. Note that it matters exactly where you are scanning with your phone. It must be in the exact location where the dish will be mounted in all three dimensions.
/ Starlink #3,732
Will it work, yes, will it be optimal, no. I was running about a 19% obstruction when I first got Starlink. It took a long time, 2 days, for it to find itself and download all the latest software. Then occasionally I would get a short period, 5-15 seconds, where nothing would load. No big deal for reading email or surfing the web... not so good for video conferences or streaming. I have since moved dishy where I am only getting about 1% obstruction and I can use Starlink for anything without issues.
/ Starlink #3,733
Ive been happy with my starlink service. However I have my router/wireless set up in my attic on the other side of the house. In the master bedroom I don’t always get a signal. I think I am going to put a mesh node in the attic on this side if the house to make it better.
/ Starlink #3,734
We've been very happy with the service and usually don't even think about it. That's so much better than our old wifi hotspot and phone tethering. Last week my son and I both had to download a 45 gbit update for a game. I scheduled mine to update overnight but he didn't. His download speed for the update was about 120 mbps even though I was playing at the time.
/ Starlink #3,735
Has anyone purchased the roaming and later switched to the residental model when it became available in their area? If so what is involved, do you have to get a new dish and hardware or can you use the dish you already have?
/ Starlink #3,736
I haven't used roaming, but in watching Starlink info in various venues I believe that the hardware is identical.
/ Starlink #3,737
I first bought RV unit while waiting for home unit. Then got home unit 3 months later. At the time you couldn’t switch RV to home, but I believe you can now.
I just sold my RV unit to another TBN person. Not sure what service they subscribed to with it.
/ Starlink #3,739
How did your speed compare from the RV to home unit and did you have any obstructions
/ Starlink #3,740
I turned RV off when I got the home unit. Swapped the antenna on the roof and the modem. Speed tests vary, can’t say speed varied any. No obstructions.
