Starlink
/ Starlink #1,981
Did you guys see this?
Elon Musk's SpaceX says a a geomagnetic storm wiped out 40 of the 49 Starlink satellites it launched into orbit last week
www.businessinsider.com.ico
Business Insider|28 minutes ago
SpaceX said 80% of the satellites it launched Thursday are expected to burn up in the Earth's atmosphere instead of reaching orbit.
I saw that. Yikes. The stated reason was that the atmospheric drag was too high to get the satellites into orbit.
/ Starlink #1,983
The issue here wasn't the electromagnetic aspects of the storm but rather the fact that it changed the atmosphere temp enough to change the drag and cause the sats to not have enough power to achieve final orbit.
/ Starlink #1,986
I received notification this past week that Starlink is ready for me (northern Wisconsin. It has been over a year, but we are anxious to receive Dishy. I'm likely to have some obstruction issues, but I'm clueless about the details of accessing Starlink. My understanding is that it is wireless now, but if I want to connect it to my mesh router then I need ro run a cable from the dish (ethernet adapter required I believe) to my mesh router. Is that correct? Given some possible location issues, I'm concerned about the possible length of the cable run from the dish to the mesh system. How do you deal with that?
Winter conditions here mean it is unlikely the Dish will find a permanent home until Spring, so I'm hoping to find a location with minimal obstruction issues --- lots of trees surrounding the house -- for temporary siting.
/ Starlink #1,987
The supplied cable will run from the dish to inside your home,
then you will need to get there dongle which will plug into the cable and provide an Ethernet connection that can go to your router,
the main cable will continue to the Starlink adapter power supply wireless router.
This is the device you need, it appears to be back ordered;
/ Starlink #1,989
So….what good is the dish without this part?
It comes with its own wifi router so you can immediately connect to it and use it without anything additional. Find a spot for the dish, connect the cables, plug it into power, power it up and then connect to the on-board wifi (after configuring with the app). You don't *need* anything else.
For people who have a networking requirements more complicated than the wifi capabilities of the built-in router (as you may, with your mesh system) you have the option to expand the system however you choose. The ethernet adapter mentioned above is one way to do that (the preferred way). You could also use other network devices to expand the wifi coverage in your home wirelessly, though those typically don't perform as well. You can add an additional router or replace the Starlink router. Lots of options.
/ Starlink #1,990
Your first task is to find a location without obstructions. Once you do that you have to plan for cable routing back to the spot in the house where you'll locate the Starlink controller/router. If the included cable length is enough for this path you're golden. I think the new rectangular dish comes with a shorter cable (75') but they offer a 150' as an optional accessory. If even 150' isn't long enough you'll have to look at other install ideas. One thing I've heard of people doing is to provide power at another location where they mount the dish and then use ethernet cable, fiber or point-to-point wireless bridge to get the signal into your home. I won't go into the pros & cons of those options... you can research plenty out there about them.
/ Starlink #1,991
I moved into a house that has been remodeled a few times. An awkard part of the house is the limited entry points from outside for cables and such for distribution to other parts of the house. In anticipation of Starlink, I ran ethernet cable from the main entry point to a closet where we currently have our mesh and DSL router. If I need to locate the Dish some distance from the house, then a long cable run could present some challenges. I guess I just have to wait for the Dish to arrive and then start problem solving.
/ Starlink #1,992
Just in case: There are a variety of 3rd party short haul RF solutions to get a signal from a remote Starlink to your house.
Try it and see how you like it. Depending on how tall your trees are, and how close they are, your roof might work.
All the best,
Peter
/ Starlink #1,993
not starlink related,,,,, and,im not sure these were posted before or not, but its a youtube video with elon musk walking thru spacex facility. about 3 hours long...but amazing video.
/ Starlink #1,994
We just drove past a huge Tesla facility going up east of Austin on 130. Glad he found something near Austin, but not in Austin. They don't deserve the influx of tax money.
For those outside of Texas, 130 is a tollway with speed limits of 80-85. Added benefit is getting to San Antonio from DFW without going through Austin city traffic.
/ Starlink #1,995
All the best,
Received notification of shipping today. Afterwards went outside and did a check of the general area where I hope to place the Dish and things look promising. The last time I used the siting app was early last summer and I found it underwhelming, but there must have been an update because it was more helpful in understand possible obstructions. if I can mount it on the eaves of the roof above one of the easy entry points into the house, then I am within 75 feet of an ethernet cable that connects to my mesh... Hoping for the best. Meantime, I spent three hours blowing snow and using my new RatchetRake Snow Edge to push around 5 inches of new snow.
/ Starlink #1,996
One thing to note, the connector on the router end of the cable is “L” shaped and rather large. I don’t see how I could fish it through the 3/4” conduit I had planned to use. Has anyone found a solution?
/ Starlink #1,997
Isn't the other end of the cable smaller? I thought I heard that the newer rectangular dishes only required a 1/2" hole (i.e. through a wall) to run cable through, versus the 3/4" needed for the choke on the round dish cable.
/ Starlink #1,998
The cable will disconnect from the dish, as much as you hate too just pull and it will disconnect.
I contacted service about the same issue as I had gently pulled and it did not disconnect.
/ Starlink #1,999
Good to know, thanks.
/ Starlink #2,000
Got our notification this evening. Located in NW Missouri. Have a friend located in Topeka KS that recieved his notification today as well.
