I have been considering buying a new tractor. I have green and orange dealers locally. If you compare a 3038E to a 3039R or a
L3901 to a
L4060 there are lots of differences, not the least of which are more weight, better hydraulics, and higher lift capacity. There may be some I am missing. Are the premium models worth it for the most part? I will be doing mostly mowing and road maintenance. My current tractor is a 1960 MF 35 diesel, so anything with power steering will be a major upgrade.
I've gone all the way back to the OP (after having read all of the other posts). You're not a newbie but you obviously want the most bang for your buck for the size (HP) that you need.
You can ultimately decide for yourself as to what
you need, plus what you would like to have, depending of the conditions that you're going to use the tractor in... that includes your terrain and conditions of use (yearly weather and fair-weather/anytime). If you use your rig daily, for extended periods of time or a physical requirement, then so-called luxuries will cut down on your own fatigue (which is a factor of comfort). That is a "premium" tractor where you can add 'goodies' to or truly up-grade.
I have a 'bare-bones' tractor. (the JD 4105) I have no 'goodies', although it does have power steering & is HST, 4WD via a lever, etc... There is no cab option with its environmental controls (but I'm somewhat of a 'fair weather' tractorer, so it's not a factor for me). There's no cruise control, no anti-vibration matting. BUT it is 41hp. Which is what I needed to handle round bales.
I could've bought 3039R (equivalent) at the time, but my salesman advised me on the
less expensive option. He sold me the tractor I needed.
So, my advice is to purchase a modern tractor 'standard/bare-bones/non-premium' rig that has the minimum requirements that
you want.
The pretties can wait 'til you're old and feeble.
[disclaimer: it's Saturday evening & I've consumed a bottle of quite excellent Shiraz!
roposetoast:]
