Stalling/Very rough
/ Stalling/Very rough #1
Hogan29980
tym
I have a TYN T264 that after around 20 mins when tractor gets warmed up begins to get very rough idling and eventual stalls out. Tractor has about 200 hours, new fuel and air filter installed but didn't help, any help would be appreciated.
/ Stalling/Very rough #2
Vent in fuel cap ( or how ever your tank is vented ) clogged?
Floating debris in tank clogging the fuel flow?
Fuel line collapsing once warm?
First few things I would check, fuel vent is easy once start to idle rough open the fuel cap to let air in and see what happens
/ Stalling/Very rough #3
According to the troubleshooting section page 4-25 of your T264 tractor's manual it could be:
Poor fuel injection
Faulty injection pump
Wrong valve clearance
Wrong idle setting
Faulty injector
/ Stalling/Very rough #4
Poor fuel injection
Wrong idle setting
Faulty injector
Mountainbuck a lot of things could cause poor fuel injection. And this is after a warm up…? These trouble shooters give you the sleeve out of their vest.
/ Stalling/Very rough #5
Does that model use an electric lift pump? If, so it’s worth check its functionality. Sounds fuel related.
Absolutely not what i was expecting. Thought is would be something related to fuel pump, injectors, etc. Noticed no change when i turned the value on and off on the fuel filter housing, unhooked it and only a small amount of fuel coming out of the line from the tank. Blew out the line running back to the tank and shazam problem solved.
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
1988 23ft Stealth Craft Boat w 1988 Arrow 22ft Boat Trailer (A61574)
1988 23ft Stealth...
(2) 26X12.00-12 TIRES W/ 5 LUG RIMS (A64280)
(2) 26X12.00-12...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
6R LAY-BY SPRAYER (A64276)
6R LAY-BY SPRAYER...
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
