Stalling an HST tractor
   / Stalling an HST tractor #1
Chain Bender
Kubota L3200
I have a fairly new (135 hrs) Kubota 3200 HST. On several occasions I have stalled the tractor at around 1800 rpms while pushing into a sand pile or pushing brush.
Last week while pushing very light briars and vines my tractor started a very loud and RPM controlled knock. I checked all dummy lights and guages and everything was fine. I shut her down and checked the oil. It was full and clean. Checked the water in the radiator and it was full and not even hot. The block wasn't hot either.
I used my dad's tractor to pull my tractor out of the woods and up on my hauler. Took it to the dealer. Stopped by yesterday and they had it in a bay and running. It sure didn't sound like it was something they were gonna fix with just the hood up. No word on cause.
A friend of mine who has owned bulldozers for 40 years said that stalling an HST under a load can/will break the crank shaft.
Anyone have a response to the last paragraph?
Thanks in advance for your opinions.
CB
   / Stalling an HST tractor #2
I've stalled my 7800 several times with a a tiller running at PTO speed when hitting a large root. Just fired it back up and kept going.
   / Stalling an HST tractor #3
I find that very hard to believe. My money is on a problem related to the fuel delivery - either pump or injectors. Fuel problems or even air in the system often sounds like a bad knock. If you broke the crankshaft on a brand new hydro machine just by stalling it, I would be absolutely appalled at the manufacturer.
   / Stalling an HST tractor #4
I doubt you've done any engine damage due to overloading the trans. HST have internal pressure relief valves which bypass fluid when excessive pressure reached.
Personally, I don't see the difference between stalling an HST or clutch transmission. Torque is torque in my mind.
On the fuel note, I had just added 5 gallons from a plastic container. But my fuel bowl looked good and I emptied it and didn't notice any debri or water.
   / Stalling an HST tractor #6
An HST naturally limits the torque that can be applied to any of the internal shafts because the torque is controlled by pump with a maximum pressure(set by a relief valve).
I stall my HST reasonably often(by pushing on stationary objects), and have never had an issue. The bigger issue with HST's is oil temperature, and if you stall for signficant periods of time, oil, and the safety valve, will overheat.
Hope its ok.
Chris
PS. With a clutch, you can get relatively large amounts of torque for very short periods of time(more than the engine will produce) because the engine has momentum.
   / Stalling an HST tractor #7
Stalling an HST is something that happens often under normal operation. Stalling the transmission is not bad, but holding the transmission in the stall mode will cause it to overheat (oil heats up in relief valve) and it serves no purpose. If the transmission stalls, you need to use a lower range or less pedal deflection. If the tractor still stalls, then you are exceeding the ability of your tractor and should find a different method or talk to your dealer about a trade-up.
Stalling the transmission should not cause an engine to fail either unless the engine lugs down. Lugging the engine can cause lack of critical lubrication and tends to produce higher combustion chamber pressure and heating. This was hardly the case with your tractor since you said the engine was maintaining 1800 rpm while the transmission stalled. If your engine failed, it had nothing to do with the transmission in my opinion.
   / Stalling an HST tractor #8
don't know if this holds true for a hst, but a friend told me once that he stalled his gear massey fergason at idle while pushing into round bales with 3ph spear (it was cold winter). started it back up and a bad knock in engine. diesel mechanic told him that rods bent. he said when stalling diesel at idle this can happen. always have some rpms when working it. i don't know how true that really is, but that is what my friend told me. i usually run my kubota b7800 at least 2000 rpms, usually 2300 no matter what. my dealer told me that you do a diesel no favors by idiling it or running it at low rpms when working it. hard on hyd hst pump and soots up engine. he said to run at higher rpms. i have and haven't had any problems with the 815 hours i have on that tractor. just some of my experiences for your info.
   / Stalling an HST tractor #9
Here is a possibility of what may have caused th knock. It could have stalled and kicked backwards enuf to restart th engine running backwards. Yes, a diesel will run backwards. I have never had it happen on a small engine but have had it happen to me with a caterpillar engine twice and an international once. Both engines knocked but were not damaged at all.
As far as the last paragraph is concerned....Not gonna break a crankshaft.
   / Stalling an HST tractor #10
CB
You mentioned that you had stalled it several times before at 1800 RPM. 1800 may not be enough power for what you were trying to do at that time. However, I find it hard to believe that would cause damage beyond the nuisance of stalling and needing to restart.
It sounds like you were only lightly loading the engine when the the knock started.
If I'm understanding correctly, the engine did not sound good when it was running at the dealer's afterward.
I'm betting that the problem is not the result of overworking the engine at 1800 RPM.
Good luck!
Let us know what happens.
   / Stalling an HST tractor #11
Possibility there was gas in that can?
larry
   / Stalling an HST tractor #12
I've stalled the HST on my B2710 a few times with no ill effects. More often I have killed the engine a mound of hard clay with the brush hog, or trying to dig with the FEL. In 900 hours and nearly 13 years no ill effects.
larry
No Sir. All of my deisel cans have black wire loops around the handles and have big "D"'s painted on the side of them. Plus I keep gas in one barn and deisel in another just to make sure. And even if I had mistaken gas for deisel, I'm sure I would have smelled it when I spilled it at the tank opening.
I thought of the same thing and went back to both barns to check and all cans were where they were supposed to be.
CB
   / Stalling an HST tractor #14
Any word from the dealer yet?
My tractors never turn less then 1500 RPM except when engaging or disengaging the PTO...that includes when setting there for a few minutes idling.
   / Stalling an HST tractor #15
Tractor diesels are derated way below the ability of the engine to produce power. Specific power of typical tractor engine is about 20HP/liter of displacement. That is why they last forever even when used at rated power output. So there is not a reason to run the engine at low RPM.
Just came home from the Kubota dealership. They had the tractor dismantled and engine out. Aked the mechanic what was wrong with it and he said the crank was broken.
But he wasn't sure if the crank broke and ruined the bearing(s) or vice versa. Anyway, shop manager took pictures to send to Kubota. Said it would be Tuesday before they heard anything back. Not sure if that meant they would agree to fix it (it is still under warranty by 14 months) or about the parts.
Anyway, it's gonna be a while before I get my little helper back.
CB
   / Stalling an HST tractor #17
CB
Must have been a faulty crank. I figure youll be provided a new engine. Depending where, a broken crank can damage the block.
larry
   / Stalling an HST tractor #18
I don't understand the physics of why stalling a HST would be any different than stalling a gear drive. Or, why stalling a low RPM motor would be any worse than stalling one that was at full RPM.... Or why stalling a motor would break a crank, I have stalled my share of them. I would think that the crank was just defective, and should be covered under warrantee.
   / Stalling an HST tractor #19
Can I ask what gear you were in at the time this happened???
   / Stalling an HST tractor #20
larry
Sure sounds like it...with only 135 hours on the machine.
Boy, that sucks!
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59905)
2019 CHEVROLET...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
