Stalling an HST tractor
/ Stalling an HST tractor #61
This is one of those break-in rules that doesn't make sense. On a tractor, 50 hours is a *long* time. I can't imagine getting a new tractor and killing 50 hours before using it for actual work. I think I would avoid long term steady RPMs at any speed, but otherwise run the engine as I'd normally use the tractor.
/ Stalling an HST tractor #62
when i got my new kubota b7800 6 years ago, the way i broke it in for the first 50 hrs, was to let it mid idle for first start of the day warm up for quite a while, no matter what the outside temperature was (15 minutes or so each time) then i ran it just shy of the rated rpms (2300). i bush hogged most of the first 50 hrs and i needed the rpms up to do that. i just kinda kept everything smooth as far as operating it, ex: easy brakings, easy into piles doing loader work, and easy direction changes on the hydrostat. other then that, i just ran it like a normal tractor. dealer even told me to do it the way i was doing it. i have 830+ hours on it now with hardly any problems what so ever along the way. i brake all new equipment in this way and i have few if any problems with it while i own it.
/ Stalling an HST tractor #63
that is what I did too.
James K0UA
/ Stalling an HST tractor #64
When I bought my 790, it had 24 hours on the meter. Finish mowing is my most typical task...which, of course, requires running at PTO RPM constantly.
All I did was stop every 10-15 minutes and vary the RPM for a minute or so, then back to mowing for another 10-15 minutes.
It was a bit of a pain..but it did break the engine in.
/ Stalling an HST tractor #65
I stalled out my HST CT230 last week plowing the driveway.
Fired it back up, kicked up the RPMs from 1800 to 2100 and didn't have any more problems.
I've been grading a couple times and caught a boulder and come to a sudden stop, but didn't kill the engine, and took my foot off the pedal before it did.
I kinda doubt stalling out under load was what caused your problem.
/ Stalling an HST tractor #66
I'm amazed an engine can run at all with a broken crank? :confused2:
How can both ends of the crank still be turning? All the accessories run off the front of the crank and the tractor is powered by the back, so was the fan and everything just sitting there while the poor motor limped along on the back 2 or 3 cyl? Seems impossible but I guess its not:laughing:
/ Stalling an HST tractor #67
My tractor's PTO RPM is 2700.
I run it at 2000 RPM on road trips between its home & my vacant property, & when bush hogging or grading.
I run it at 1700 - 1800 RPM when doing most other tasks, like lifting debris with the loader.
I run it at 1500 - 1700 RPM when moving around the property between tasks doing nothing much but moving.
I even sometimes move the tractor a little ways here & there at or just barely above idle.
I hope this isn't harming the tractor, but RPM above 2000 just seems very unnecessarily excessive for anything I do with the tractor (so far).
Also, I have Stall Guard HST+ (auto maintains RPM) and Auto H-DS (auto downshifts to Turtle when load increases), so maybe those two features offset some power deficiencies I may have by running the RPM "too low".
/ Stalling an HST tractor #68
These break-in statements are in the book but do they really intend a person to comply? My first engineering job was self propelled combines. You only run full RPM or your machine won't run right. Shortly after I started at Allison-Chalmers we replaced our tractor gasoline engines with Chevrolet engines to save bucks. No special break in req'd - 3,000 full load rpm, 3200 high idle from the start. We used about every engine A-C ever built, and then switched to Deutz when they bought us out. No break-in, go to the field and run full power & speed. Then I switched to Cat for the next 20 years. My first project was a cold planer for milling up asphalt. 1,000 HP, V-12, and no babying that. Accompanied first machine to a job site. Operator started it, warmed it up, and then we went to milling with the computer set to keep it at 95% power holding 5% as a cushion. So when I get my new L5740 I read that blurb about low load low speed break-in. My thought is what did I buy, a toy or a working tool. If I have to spend the first week pulling the cart I use behind my lawn tractor up and down the road to break it in they can take it back. But Kubota engines are used in other makes and they don't require babying them so I have used mine like a work tool.
/ Stalling an HST tractor #69
I don't know that I've ever seen an emergency backup generator that has run at anything less that full rated RPM from the first start. Crank 'em cold from the initial start and go to full rated RPM in 5 seconds or less. Doesn't seem to hurt them a bit.
/ Stalling an HST tractor #70
Make sure you are not collecting water in your front axle.
/ Stalling an HST tractor #71
I thought I would revisit this post and try to educate myself further....
I recently was tilling with my new JD3038 and 57" rototiller. I was not on virgin ground, but ground that had already been worked. I set my tiller a little deeper this time and wound up finding a fence post. The RPMs at the time of this encounter were somewhere around 2200-2500 (I don't know if you would consider this low RPM or not). It all happened very suddenly and the next thing I knew the tractor was silent. I started it right back up to ensure proper cooling.
My questions below stem from reading numerous posts and in talking with the dealer.
In layman's terms, it sounds like even with the slip clutch set correctly, a HST possesses a relief valve that acts somewhat like a "fail safe" (dealers term) and ends up killing the tractor. Is this what the bypass "relief" valve is intended for? Can I take comfort in knowing that my tractor did what it was supposed to do to prevent any further damage?
Also, to further confuse me, I was told in a HST tractor you should expect it to stall from a jammed tiller as soon as you take your foot off the pedal. I imagine this is exactly what happened since I was startled and froze. Again, is this another fail safe or just a design function? I can't imagine I am supposed to press harder on the pedal and increase the RPM's to power through it.
To sum it up, with the slip clutch set properly like the dealer ensured me it was, I am curious how to avoid this in the future if I hit another hidden object.
Clear as mud?????:) I guess along with being educated I was hoping to find a little piece of mind.
BOC
/ Stalling an HST tractor #72
It would seem to me the resistance of the tiller thru the PTO stalled the tractor. If you press harder on the Hydro pedal, that would tend to make the wheels move faster and therefore jamb more untilled soil down the throat of the tiller thereby increasing the load on the tiller and the pto and stalling the tractor engine. If you let off the pedal or raised the 3pt then the tiller would have less resistance from the unbroken ground and would lessen the load on the PTO and the engine. In other words, go slower and let the tiller have time to chew up the soil and lessen the load on the tractor and/or raise the tiller a little with the 3pt so it does not dig so deep all in one pass and thereby lessen the load on the tractor.. Thats what I think..
James K0UA
/ Stalling an HST tractor #73
I have the slip clutches set to where they will bog the engine down a bit, but slip and not kill the engine.
I would check the manual to see how your slip clutch should be set as opposed to just taking the dealer's word for it.
I am not sure I get the HST fail safe as the PTO doesn't run through the HST and should be no different than a geared unit or at least I can tell no difference between our geared independent PTOs and HST, but I am not a mechanic so I may be way off.
/ Stalling an HST tractor #74
Both good points. I just want to be clear, the tractor didn't stall because I overloaded the tiller, it stalled because I struck a fence post that got tangled in the tiller. Also, my owners/operators manual for my Frontier tiller and bush hog both do not say anything specific about how to set the slip clutch. It is very vague and they just mention to check it.
/ Stalling an HST tractor #75
To me at least how it got overloaded is less important than how it reaxted when it did.
I overload both our cutters, one on a L5030 HSTC and one on a M8540 HDC a few times every year hitting unseen obstacles and the engines don't die, the slip clutches slip.
/ Stalling an HST tractor #76
From what I think I got from your description, it seems normal, but maybe your slip clutch is a little too tight. Maybe, that is.
Just like stalling a stick-shift car: Put the front bumper of the car against a wall & start slowly slipping the clutch, & for a while it will slip & just start slowing engine RPM. Let the clutch out too far & the engine dies of course. I think you did basically the same thing, but all at once quickly. So 1) you either loosen the slip clutch so it can (almost) never kill the engine, which may cause some unnecessary slipping during normal operation when it encounters extra hard dirt or you're driving too fast, or 2) just know that once in a while you may kill the engine if you're not quick enough to turn off the PTO. Regardless of what you're doing with the HST pedal, if the PTO can't go, & can't slip enough, then the engine can't go, ie letting off on the HST pedal will give the engine a little more RPM & therefore give the PTO a little power boost, buy enough to grind up a fence post? Doesn't seem like it. Prob no real harm done, & prob normal operations. All IMO of course :)
/ Stalling an HST tractor #77
Sorry somehow I missed the part about the fence post, OK then well it sounds like the slip clutch on the tiller should have slipped and it did not. as that fence post was a sudden drag on the PTO. There have been several threads about adjusting the slip clutch on here, and also you might try another brand of tiller manual, I know King Kutter has theirs on line and I think they have a procedure to adjust the slip clutch in their manual.. Of course it could be a different slip clutch too. so watch out..
James K0UA
/ Stalling an HST tractor #78
I set my tiller's slip clutch on the loose side. When you adjust your clutch, be careful to loosen each tension bolt exactly the same number of revolutions until it slips as soon as you lower the tiller to the soil. Tighten the bolts evenly until you can till normally in untilled soil with no slippage. My tiller's clutch slips when I hit any obstruction in the ground or even if I go too fast. I'd rather have it that way than be too tight. I've had a rock catch my tiller and not realize it until the clutch starts smoking. Even so, the clutch seems to have suffered no damage and certainly my tractor didn't have the stress and shock of an instant engine stall.
2019 KUBOTA SVL95-2S SKID STEER (A64279)
2019 KUBOTA...
2017 Case CX145D (A62177)
2017 Case CX145D...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A61573)
2005 Anderson 24ft...
EZ Trail 3400 (A63688)
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
