Stained Concrete
/ Stained Concrete #1
MLinOleMiss
Collins, MS
Mahindra 4110
My wife and I are in the process of purchasing a home and would like to pull up the old flooring and stain and seal the concrete. The main reason is my son suffers from severe allergies and carpet tends to hold dust and dirt. Ceramic or wood are way too expensive and vinyl looks cheap. I spoke with a contractor and he quoted me $6.50 a sq/ft (with us pulling up the old flooring). At 2500 sq/ft, he isn't an option, especially after I did some online research and legwork and found that I could get the needed materials for less than $1,000. I am self-employed and the wife is a school teacher, we both have retired dads that are very handy in home repair, so the labor to get up the old flooring will not be an issue. I was wondering if anyone has done this and what the results were. Thanks.
/ Stained Concrete
/ Stained Concrete #3
At a woodwork shop I used to work in we had concrete floors.
I spent a year in the paint/stain shop.
One day I spilled half a 5 gallon bucket of stain on the floor.
Cleaned it up as quick as I could, but it left a huge stain on the floor.
I would think that if you wanted it to happen then it would be that easy.
Pour it on, mop it around, wipe it off. Repeat to get more color depth.
The shop had smooth finish concrete floors.
If you have wood over concrete it mite not be that smooth.
Pooh Bear
/ Stained Concrete #4
Pooh Bear
/ Stained Concrete #5
Thats a tough call if you want it done right. The stained and patterned concrete process starts with the original pour and involves more than people think. To retro finish a slab that never was meant to be exposed is gonna be tough, unless its a very smooth finish under the carpet. My suggestion to you would be to look into a laminate flooring, these can be had for ~$3/ft and can be installed yourself. They go down pretty easy and places like Home Depot will assist. Ceramic tile also is a good way to go, and sometimes tile outlet stores have great bargains, installation however will require a little knowledge to get a pro looking job. Another cheaper option is to use a 2 part epoxy paint, this will give you a very tough and slick surface, it might look a little industrial, but relatively easy to apply. Good luck.
/ Stained Concrete #6
/ Stained Concrete #7
I just stained and seal 1500 sq ft of basement rec room. We have hot water heat in the floor, and My wife wanted something indestructible for her dogs. I have to say it worked pretty well. First I ordered a sample Kit of 6 or so colors and tried some test areas. You have to watch it cause it can get to dark pretty easy. What I did was ordered the lightest color (Amber I think), diluted 1 part stain to 2 parts water (by the way this is acid stain, not the stuff at home depot). I masked a tile pattern on the floor using 1/4" tape, with and exterior border all around the room. It was very important to super clean the floor ahead of time. Used a cheap garden sprayer to put on 1 coat of stain, then did a second coat on the outer border area, it made that portion a dark shade. Then after is set for several hours, scrubbed and wash out the floor with water and baking soda (Neutralizes the acid). Then using the same sprayer put on about 5 coats of sealer. It left a little bit of a ruff finish, I wish the sealer had formed a perfectly flat seal like a varnish might have done. Either way it looks great. I would do it again in a minute. Patina of the concrete come through and there is all kinds of variation in how the stain looks.
/ Stained Concrete #8
/ Stained Concrete #9
<font color="blue"> Here's </font>another option instead of stain. Their FAQ says the cost is about $1 sq/ft for the materials for a basic three color job.
/ Stained Concrete #10
/ Stained Concrete #11
Where did you get your materials and sample kit from?
/ Stained Concrete #12
/ Stained Concrete #13
I got it off one of those EBay stores. Shopped around a lot, their price was cheapest. I think the name was Concrete Depot.com. I bought (1-case) 4 gallons of stain ($179?) 2-5 gallan cans of sealer ($94 Each). The sample kit was something like $20. You have to keep an eye on what the shipping costs are, I think there are some epa restrictions on how acid stain can be shipped. I found some pretty big variance in the what companies were charging for the shipping.
/ Stained Concrete #14
/ Stained Concrete #15
Did you consider the snap together laminates? There are some cheap one and some very good ones. Some look like tile, others look like wood, etc.
Just put down Shaw brand in kitchen at relative's, looks like tile. It is extra thick because we didn't like the thin stuff that gives when you walk on it. Looks nice!
-JC
/ Stained Concrete #16
-JC
/ Stained Concrete
We are considering the snap together stuff for a couple of the rooms.
/ Stained Concrete
/ Stained Concrete #19
I bought the Quicrete brand stain from Lowes and would strongly recomend you avoid it.
We were looking to experiment and thought it was a name brand that would do the job for minimal expense. We followed the directions, used all their materials and took our time to get it right.
The finished look was just what we wanted.
Unfortunately it didn't realy stain the concrete, but is more of a finish that chips off.
Next time I'll look at the more profesional stains from a specialized store and avoid the box stores all together.
Eddie
/ Stained Concrete #20
Eddie
2020 POLARIS SPORTSMAN HIGHLIFTER XP-1000EFI ATV (A62131)
2020 POLARIS...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
208320 (A58375)
208320 (A58375)
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
2011 Mack GU713 Granite Dump Truck, VIN # 1M2AX07YXBM010053 (A61165)
2011 Mack GU713...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
