Stability improvement
/ Stability improvement #1
Youare
Platinum Member
Winchester, New Hampshire
Kubota L3000
I have a Kubota L3000DT which I use some of the time to go into the woods to do some light logging, it has a Farmi winch on the back. I take out a few saw logs and a lot of fire wood.
I recently moved the rear wheels to the widest setting and the difference that has made in stability is notable. The difference in width is only about 6" on a side but that little bit makes a world of difference.
I would suggest that any one who drives their tractor on uneven ground set the wheel width to its maximum.
Randy
/ Stability improvement #2
It is surprising how much difference a few inches of added width will make in stability. I found loading the rear tires with liquid ballast also makes a dramatic difference in stability as well as traction.
MarkV
/ Stability improvement #3
Mark,
I also think that loading the tires makes a great improvement in stability and traction... It's far superior to wheel weights also....
Regards,
Chris
/ Stability improvement #4
How did you move the wheels? I have been comtemplating this but thought the weight of my rear wheels would be too much to handle without an overhead hoist. My tires are filled as well. I was planning on taking it in to my dealer for this.
Also, did you move the front out as well?
Chuck
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
Deere 700K (A64126)
Deere 700K (A64126)
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
