squirrel damage
/ squirrel damage #2
Dave, trapping the squirrels won't do you much good, unless you intend to make it a full time occupation. There are just too many of them for you to even make a dent. The problem is, is that something about your tractor is attracting them, and enticing them to chew the wires. Don't even try to figure that out, you probably never will. What you have to do is make it not attractive to them. The easiest thing to do, is to put some mothballs under the hood, where they won't interfere with anything. Like most creatures, squirrels hate the smell of mothballs, and that should keep them away. Easy, and not too messy!
Good luck!
Rich
/ squirrel damage #3
I've had two incidents with the little red squirrel devils.
First, they chewed through the wood overhang facing on the North side of the house, getting into the attic. That really torqued my jaw, as I try to have agreements with all of the critters..........don't mess with me and I won't mess with you. So, I set rat traps in the rain gutters and attached them with wire to the gutter spikes. It was interesting when a red squirrel got caught in the trap, started "flailing", and was hanging off the trap and wire swinging back and forth. My wife was a bit distressed, then realized what the little critters were doing to the house.
Second incident involved dog food and my truck's air cleaner. We used to feed the dog in the garage, and occasionally she'd leave a few nuggets of food in her dish. One day I was hauling a pick-up load of wood up from the back and the truck just seemed to be coughing and having a real hard time running. Pulled into the barn and started to check things over. When I popped the top off the air cleaner and pulled the filter, the whole intake pipe was packed full of dog food nuggets........no air flow to the fuel injectors. Since then we feed the dog in the coat room off the garage.
Squirrels can be nasty little critters, at times. My dog has some type of personal vendetta against them and spends some part of every day stalking them around the house and through the trees. Not often, but occasionally, she gets one.
Bob Pence
/ squirrel damage
Rich:
Thanks, really good idea. They did't get the tractor, only the F150 pick-up truck. There is one particular squirrel that I think is the culprit tho. I'll do the moth ball thing, but I'm going to trap that one little bas&#@d anyway. I set the trap last night and realized that my behavior closely resembled Bill Murrey's in Caddy Shack.
/ squirrel damage
Thanks Bob:
In my past life I worked for 25 years in a fire department, most of it in the fire marshal's office. I remember hearing about electrical fires originating in people's attics caused by squirrels chewing on the wiring insulation. I never investigated one myself, but heard of several. Keep out the squirrels or buy a whole bunch of conduit and rewire the house.
Glad to hear that your rat traps worked. I'm going to try the moth balls today but the Havahart trap is set.
/ squirrel damage #6
dsquared, I just came back from visiting my two brothers. One of them was rewiring a 60' cable from the backup camera to the monitor on his motorhome. This is the second time in 3 years squirrels have chewed into it. He also had to rewire some of the 12 volt wiring to his clearance lights. He has one of the Havahart traps set, two artificial (rubber) snakes on the ground where they get in, and he tried putting mothballs in the channel at the top where they chew the wiring. He said they just carried the mothballs out and dropped them on the ground./w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Bird
/ squirrel damage #7
Re: squirrel damage/mothballs?
Since we're talking about mothballs /w3tcompact/icons/laugh.gif (off-topic alert); Where do you guys GET mothballs anymore?
My reason for asking is the off-topic part - years ago my mom used to make a Christmas decoration out of one of those great big "brandy-glass" type of fishbowls. She'd put a mix of something (vinegar? baking soda?) in some colored water, and drop mothballs in it. Some kind od chemical reaction took place that changed the weight of the balls (bubbles on their surfaces?) and they would go up -then down, on and on. Made an interesting colored snowball-fight in-a-jar, sort of thing. We kids loved watching it.
Mom's older now, and can't remember how she did it. Anybody (or anybody's wife) know anything about this?
Thanks,
Larry /w3tcompact/icons/smile.gif
/ squirrel damage #8
Sure is off-topic, but not really, as we've used mothballs for years to (temporarily) get squirrels & deer to stay way from something. Doesn't work long, as mothballs in open air decay rapidly.
As for your question:
<font color=blue>Where do you guys GET mothballs anymore?</font color=blue>
I get mine at the local pharmacy. This is usually in small (1#) packages. Don't know where you'd go for larger quantities. /w3tcompact/icons/crazy.gif
The GlueGuy
/ squirrel damage #9
Get them at your local friendly Wal-Mart store. They are in the Housewares Dept. close to the clothes hangers.
/ squirrel damage #10
Larry, I think I've heard of that trick with the mothballs, but neither my wife nor I can remember what you use in the water. And like the other guys, my wife says you can get mothballs at both Wal-mart and K-Mart. She got me some awhile back to scatter around in my workshop to see if that would help keep the insects and mice out. I'm still not sure whether it helped any or not.
Bird
/ squirrel damage #11
The newer, more kindly moth balls don't work for me, but the older, evil smelling ones that contain naphthalene do.
Ed
/ squirrel damage #12
Ed, that shows how much I know about mothballs; didn't know there was more than one kind./w3tcompact/icons/smile.gif
Bird
/ squirrel damage #13
How about a squirrel bring down a generating plant? The plant where I work had a squirrel come in along the electric lines and just happened to jump off in the middle of the main transformer. Fried squirrel and the plant was down a few days for repairs. The big question is where did the little bugger get on the power line, he must have been walking for miles to reach the end of the line....
TC33D
/ squirrel damage #14
Two years ago, my dad's cleaning lady called me at work to ask how she could contact my dad as something 'strange' was going on in his townhouse. My dad was at the Ocean for the week, and on her day to clean, she let herself in and found shredded paper in the den. She cleaned that up, went upstairs and cleaned up there. When she came back down, there was more shredded paper (from the fanfold computer paper). When I got there, we realized it was a critter, ended up being a squirrel, got in thru the cloths dryer vent (flapper valve was stuck open) and chewed thru the plastic vent hose and 'had the whole house to himself'. We opened up the back door and ended up herding him out. Ended up putting chicken wire over the dryer vent.
Steve
/ squirrel damage #15
Have the same problem, what a coincidence. First year we've had red squirrels....wonder what attracted them. I do know how I will get rid of them--.410. One in particular has not only made my seldom used F150 into a storehouse for nuts, but now has moved into the frame rails of my new F250......gotta go. Appears on 5 or 6 total on the property. Reading this, I'm going to address it before I end up with more.
Had a friend years ago with a cedar roofed house. Red squirrels were a constant problem--even getting in the house after chewing through the roof! He tried many things, then finally an electrified grid of sorts (bought commercially). Well it worked fine, zap, then smoke, then fire (squirrel and roof)...fortunately he put it out with a garden hose.
/ squirrel damage #16
Bird, I've heard that everything in Texas is bigger and tougher, but squirrels carrying out mothballs, and dropping them on the ground is amazing. Even your squirrels are tough! In New York, they won't go near mothballs, and certainly would never carry them, or even touch them. I'd hate to have to deal with your bigger animals!!! /w3tcompact/icons/smile.gif
Rich
/ squirrel damage #17
Rich, I don't think they're any bigger, but maybe they have to be tougher to survive our summers./w3tcompact/icons/laugh.gif Squirrels are amazing critters. My dad was an avid squirrel hunter (on the farm) but didn't want anyone bothering those around the house in town, even after one got in the attic, chewed through the acoustical tile in the ceiling, fell into the house, then starved to death while they were gone for several months and he forgot to close one of the attic vents before they left. I haven't killed or eaten a squirrel in many years, but may have to change that because they're getting thicker around here, too. So far no damage other than them eating my pecans./w3tcompact/icons/laugh.gif
Bird
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2023 VOLVO L90H WHEEL LOADER (A64279)
2023 VOLVO L90H...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
