Squeeky Loader
/ Squeeky Loader #1
nebuniram
PNW
Yanmar F22d, Cat E70b
Hello,
I have a question regarding my Koyker 120 loader on my F22D. It makes a "squeeking" sound everytime I lower the loader but not when I lift it:confused: . It kinda sounds like when you turn your Car tires on smooth garage cement like a parking garage. Is this just the seals? Do I need to lubricate the piston arms? The loader is brand new, has about 5hours of use.
Thanks -Joe
/ Squeeky Loader #2
Joe,
You do not need to lubricate the "piston arms" [cylinder rods?], when the cylinders are retracted they are bathed in oil. Each pivot point should have a grease fitting though, I am not sure how Koyker does it, but sometimes the grease zerk is in the end of the pin, sometimes in the middle of the of the pin section, and sometimes next to the end of the pin. I would make sure that each pivot pin was greased. There are several of them both ends of the loader arms (lift pivot and bucket pivot), both ends of the hydraulic cylinders (the cylinders may or may not have grease fittings).
Beyond that it may just simply be "brand squeaky new." However, I suspect it needs grease.
Mike in Warsaw
/ Squeeky Loader #3
Or something may be loose, allowing for part of the assembly to rub. Check everything for tightness (EVERY bolt and pin) and grease the fitting in the middle of each pin where cylinders attach.
Lastly, are you sure it's not a squeal, such as the hydraulics struggling?
/ Squeeky Loader #4
I had the same prob. One of the fittings on the lift arms was int taking grease. Make sure that when you grease it that grease does not end op on the outside of the fitting. If it does remove the fitting and replace it or clean it.
/ Squeeky Loader
Thanks everyone, I will check all bolts and pins for tightness and make sure the grease is getting in. Hopefully i find something loose or ungreased and the problem dissapears.
-Joe
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2015 JOHN DEERE 644KH HYBRID LOADER (A66091)
2015 JOHN DEERE...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
