Square tubing question
/ Square tubing question #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I need a nice slide fit on some 2'' square tubing. I need to slide a 2'' piece into a 2.5'' piece with little slop.Just trying to get the wall thickness right to do this. Would a 2.5 with a 0.25 wall be what I need to take up the slack or would that be too tight?. Thanks for any info.
I see 0.12 ,0.1875 ,and 0.25 online.Unfortunately I have to get this online and can't test fit them.
After reading my post it seems like a really dumb question.:confused:
/ Square tubing question #2
Not dumb, but I think you answered your own question. If I recall correctly 2 1/2 1/4wall tube would be 2 in id,
What I did in your situation was buy a piece of reciever stock, 2 inch slides inside perfectly. It cost a bit more but is also thicker wall I think 1/2 if I recall
/ Square tubing question #3
Are you looking for trailer receiver square tubing? 2.5 X 2.5 X .250 is used for trailer receivers. What is the wall thickness of the 2 X 2 tubing? Only some size work. The corner radius sometimes bind.
Cary:cool:
/ Square tubing question #5
Cary:cool:
My question too. HF has standard receiver tube 18"L for $15. Item #97093-0AXH.
larry
/ Square tubing question #6
The square tube will have a welded seam inside unless you purchase special tubing
/ Square tubing question #8
agrisupply sells a receiver that is 6" long for less than than $10, I got 3 of them, and they work great
/ Square tubing question #9
see#5
larry
/ Square tubing question #13
I read someware that they run a broach through the tube to clean up the inside weld..........Larry
/ Square tubing question #14
I use the 2 1/2 x 1/4" wall all the time for receivers and never had a problem with the seam on the inside.
/ Square tubing question #16
What is called for is "slip tubing" - it does not have the welded seam inside or the rounded corners. We used it in a plant manufacturing big fertilizer applicators (did on 110' long). The purpose was to stiffen the tongue. The frame IIRC was built from 4" heavy wall tube with a center rib of 4" slip tube down the middle. A chunk of 3 1/2" heavy wall was shoved into that.
We 'liberated' enough of both to build 7 wood splitters using it for the slide.
Mine is #7. :)
Harry K
/ Square tubing question #17
I use 2.5" x 3/16" for the outer and 2" x 3/16" for the inner. The result is a 1/16" gap for the slip fit and consistant corner radius.
/ Square tubing question #18
I agree with Gizmo....I also use 2 1/2 x 2 1/2 x 3/16" wall. It is good and loose, but not too loose. Works great and if it gets a little dirty, you won't have to beat it in with a pipe.
NEW, ATS Mini Excavator (A62679)
NEW, ATS Mini...
(3) 17.5-25 industrial tires on Deere 14-lug grader rims, Coal Valley, IL (A65640)
(3) 17.5-25...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
