Square tubing question
/ Square tubing question #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I need a nice slide fit on some 2'' square tubing. I need to slide a 2'' piece into a 2.5'' piece with little slop.Just trying to get the wall thickness right to do this. Would a 2.5 with a 0.25 wall be what I need to take up the slack or would that be too tight?. Thanks for any info.
I see 0.12 ,0.1875 ,and 0.25 online.Unfortunately I have to get this online and can't test fit them.
After reading my post it seems like a really dumb question.:confused:
/ Square tubing question #2
Not dumb, but I think you answered your own question. If I recall correctly 2 1/2 1/4wall tube would be 2 in id,
What I did in your situation was buy a piece of reciever stock, 2 inch slides inside perfectly. It cost a bit more but is also thicker wall I think 1/2 if I recall
/ Square tubing question #3
Are you looking for trailer receiver square tubing? 2.5 X 2.5 X .250 is used for trailer receivers. What is the wall thickness of the 2 X 2 tubing? Only some size work. The corner radius sometimes bind.
Cary:cool:
/ Square tubing question #5
Cary:cool:
My question too. HF has standard receiver tube 18"L for $15. Item #97093-0AXH.
larry
/ Square tubing question #6
The square tube will have a welded seam inside unless you purchase special tubing
/ Square tubing question #8
agrisupply sells a receiver that is 6" long for less than than $10, I got 3 of them, and they work great
/ Square tubing question #9
see#5
larry
/ Square tubing question #13
I read someware that they run a broach through the tube to clean up the inside weld..........Larry
/ Square tubing question #14
I use the 2 1/2 x 1/4" wall all the time for receivers and never had a problem with the seam on the inside.
/ Square tubing question #16
What is called for is "slip tubing" - it does not have the welded seam inside or the rounded corners. We used it in a plant manufacturing big fertilizer applicators (did on 110' long). The purpose was to stiffen the tongue. The frame IIRC was built from 4" heavy wall tube with a center rib of 4" slip tube down the middle. A chunk of 3 1/2" heavy wall was shoved into that.
We 'liberated' enough of both to build 7 wood splitters using it for the slide.
Mine is #7. :)
Harry K
/ Square tubing question #17
I use 2.5" x 3/16" for the outer and 2" x 3/16" for the inner. The result is a 1/16" gap for the slip fit and consistant corner radius.
/ Square tubing question #18
I agree with Gizmo....I also use 2 1/2 x 2 1/2 x 3/16" wall. It is good and loose, but not too loose. Works great and if it gets a little dirty, you won't have to beat it in with a pipe.
Rhino 3-Pt. Forklift for Tractor (A66408)
Rhino 3-Pt...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
(2) 18x38 Rims (A65640)
(2) 18x38 Rims...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
