Square tubing question
   / Square tubing question #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
I need a nice slide fit on some 2'' square tubing. I need to slide a 2'' piece into a 2.5'' piece with little slop.Just trying to get the wall thickness right to do this. Would a 2.5 with a 0.25 wall be what I need to take up the slack or would that be too tight?. Thanks for any info.
I see 0.12 ,0.1875 ,and 0.25 online.Unfortunately I have to get this online and can't test fit them.
After reading my post it seems like a really dumb question.:confused:
   / Square tubing question #2
Not dumb, but I think you answered your own question. If I recall correctly 2 1/2 1/4wall tube would be 2 in id,
What I did in your situation was buy a piece of reciever stock, 2 inch slides inside perfectly. It cost a bit more but is also thicker wall I think 1/2 if I recall
   / Square tubing question #3
Are you looking for trailer receiver square tubing? 2.5 X 2.5 X .250 is used for trailer receivers. What is the wall thickness of the 2 X 2 tubing? Only some size work. The corner radius sometimes bind.
Cary:cool:
   / Square tubing question #5
Cary:cool:
My question too. HF has standard receiver tube 18"L for $15. Item #97093-0AXH.
larry
   / Square tubing question #6
The square tube will have a welded seam inside unless you purchase special tubing
   / Square tubing question #8
agrisupply sells a receiver that is 6" long for less than than $10, I got 3 of them, and they work great
   / Square tubing question #9
see#5
larry
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
Informational Lot - Financing (A53473)
Informational Lot...
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
2023 JOHN DEERE 8R370 LOT NUMBER 201 (A53084)
2023 JOHN DEERE...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
