Square Bended U-Bolts
/ Square Bended U-Bolts #1
db05
Having problems finding some larger sized square bended U-Bolts and was wondering if you could help. Sizes:
2 x 5, 1/2 inch diameter
4 x 7, 3/4 inch diameter
Thanks for your help.
/ Square Bended U-Bolts #2
You might be able to have some made up at a spring shop.
/ Square Bended U-Bolts #3
Look for a driveline or 4x4 shop in your area. Most places set up to do driveshafts have the press to make u-bolts.
/ Square Bended U-Bolts #4
db05, Depending on what your doing with them , One quick and easy idea is to get a piece of all thread the diameter you need put it in the vise heat with torch and bend it, then cut to length needed....
I wouldn't try to hold my truck springs on with this method though... /forums/images/graemlins/crazy.gif
/ Square Bended U-Bolts #5
You might call a local Napa and see if they know of anyone in your area that makes U-bolts. I had some made up for my truck a couple of weeks ago at a small local garage. They were the only place less than an hour away that makes them.
/ Square Bended U-Bolts #6
db05,
Ditto what Redrocker said.
I'd grab the phone book and find a shop that makes them. If you put the word out to some of the better auto parts stores, they should be able to point you in the right direction.
/ Square Bended U-Bolts #7
dbo5, Some trailer axles are square and require that style U bolt. Threaded rod is not very strong and a little harder to keep tight depending what you are using it for?
Some farm implements use that style as well. Maybe a implement dealer can match them up??
Just something else to think about.
Ronald
Ranch Hand Supply
I'll be using these as part of a frame for holding forklift forks to be attached to a tractor loader so they need to be strong. Would this work, purchase some 1/2 & 3/4 round stock steel from my local steel yard, heat it, bend it using square tubing as my guide and then use a pipe threader for my threads? Those pipe threaders from Harbor Freight any good? Thanks again
/ Square Bended U-Bolts #9
db05,
Don't know where you live but if near water, check with a marina. Many boat trailers use them.
Brian
/ Square Bended U-Bolts #11
I would get standard auto/truck spring shackles from a junkyard, etc. , and fabricate something to square up the "U".
/ Square Bended U-Bolts #12
A suggestion. When U bolts get that large on implements, I try not to use them. I usually use 2 bolts and two heavy straps with holes in each end. That way you can make them any size you want.
/ Square Bended U-Bolts #13
dbo5, I think JerryG is correct with his idea ! Since we know what you are trying to achieve.
Ronald
Ranch Hand Supply
JOHN DEERE LV4115 TRACTOR (A63276)
JOHN DEERE LV4115...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
213137 (A64276)
213137 (A64276)
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
2022 Tesla Model 3 Long Range AWD Sedan (A64557)
2022 Tesla Model 3...
VERMEER FT 100 FORESTRY MULCHER (A65053)
VERMEER FT 100...
