Square Bended U-Bolts
/ Square Bended U-Bolts #1
db05
Having problems finding some larger sized square bended U-Bolts and was wondering if you could help. Sizes:
2 x 5, 1/2 inch diameter
4 x 7, 3/4 inch diameter
Thanks for your help.
/ Square Bended U-Bolts #2
You might be able to have some made up at a spring shop.
/ Square Bended U-Bolts #3
Look for a driveline or 4x4 shop in your area. Most places set up to do driveshafts have the press to make u-bolts.
/ Square Bended U-Bolts #4
db05, Depending on what your doing with them , One quick and easy idea is to get a piece of all thread the diameter you need put it in the vise heat with torch and bend it, then cut to length needed....
I wouldn't try to hold my truck springs on with this method though... /forums/images/graemlins/crazy.gif
/ Square Bended U-Bolts #5
You might call a local Napa and see if they know of anyone in your area that makes U-bolts. I had some made up for my truck a couple of weeks ago at a small local garage. They were the only place less than an hour away that makes them.
/ Square Bended U-Bolts #6
db05,
Ditto what Redrocker said.
I'd grab the phone book and find a shop that makes them. If you put the word out to some of the better auto parts stores, they should be able to point you in the right direction.
/ Square Bended U-Bolts #7
dbo5, Some trailer axles are square and require that style U bolt. Threaded rod is not very strong and a little harder to keep tight depending what you are using it for?
Some farm implements use that style as well. Maybe a implement dealer can match them up??
Just something else to think about.
Ronald
Ranch Hand Supply
I'll be using these as part of a frame for holding forklift forks to be attached to a tractor loader so they need to be strong. Would this work, purchase some 1/2 & 3/4 round stock steel from my local steel yard, heat it, bend it using square tubing as my guide and then use a pipe threader for my threads? Those pipe threaders from Harbor Freight any good? Thanks again
/ Square Bended U-Bolts #9
db05,
Don't know where you live but if near water, check with a marina. Many boat trailers use them.
Brian
/ Square Bended U-Bolts #11
I would get standard auto/truck spring shackles from a junkyard, etc. , and fabricate something to square up the "U".
/ Square Bended U-Bolts #12
A suggestion. When U bolts get that large on implements, I try not to use them. I usually use 2 bolts and two heavy straps with holes in each end. That way you can make them any size you want.
/ Square Bended U-Bolts #13
dbo5, I think JerryG is correct with his idea ! Since we know what you are trying to achieve.
Ronald
Ranch Hand Supply
KOEHLER GAS POWERED GENERATOR (A64278)
KOEHLER GAS...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
