Sprinklers
/ Sprinklers #11
As an irrigation contractor for over 20years, I would say the old faithful Hunter PGP series, Also we have been having great sucess using TORO #800 series sprinkler, adjustable from say 40deg to a full 360deg. How many GPM are you using/ Pressure? I think you will be happy with a gear driven sprinkler,
I use the Hunter PGP series too with very few problems, easily adjustable and good coverage. These come in full circle 360 and adjustable arc models, all can use a multitude of nozzles tips to allow for various flow rates.
FWIW, larger supply pipe really makes a difference in the efficientcy of a sprinkler system, try to limit the amount of 3/4" pipe in your systems. I run 1 1/2" main lines with short 1" lines to the valves and heads.
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2013 Ford F-150 Crew Cab Pickup Truck (A59230)
2013 Ford F-150...
1996 Ford Ranger Pickup Truck (A59230)
1996 Ford Ranger...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
Cat CB24B (A60462)
Cat CB24B (A60462)
