Spreading sand
/ Spreading sand
Now that gives me some ideas.:scratchchin:
Thanks Aaron Z
/ Spreading sand #14
I've recently bought a snow ex mini pro 575 which has a direct auger in to the material, directly attached to the spinner. That's all run by 12v electrics, attached to my vans battery. It also has a vibrator for wet salt, to prevent clogging.
Snow ex do the next model up -1575 I think, that has a horizontal auger, then the spinner, so you adjust the spinner speed individually of the auger, so you can throw a small amount a long way or vic versa.
I didn't think I need that model, but, after using my model, I can see where the second auger would come in to its own now. K
P g k
/ Spreading sand #15
I had this same issue with my cone spreader. A few things I did is try to keep the spreader as low as possible and reduced the RPM as much as possible. That is the only way other then like you mentioned, adding some shields. I have a gear tractor so I put it in a higher gear and adjust the RPM with the pedal.
For some of the others, reducing the flow isn't the issue its throwing the sand wider then his road.
/ Spreading sand #16
Could you tilt the whole spreader backwards, so the spinner is unlevel? This might waste more sand, as it might be deflected off the plate more quickly, this throwing it less far?
Or, baffle plates to each side seem the easiest solution, to deflect spread?
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Morgan 26ft Box Truck Body (A59230)
Morgan 26ft Box...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
