Sprayer
/ Sprayer #1
Rch
Platinum Member
Central Wisconsin
1986 Ford 1910 with 770B (FORD) loader, 4 MFWD; 1986 Bolens G214,back hoe,loader,MFWD (Iseki) 21 hp)
Enclosed are photos of a sprayer I built for spraying Round-up prior to planting trees. The 1st photo shows a smaller ‘ gathering tank’ under the 35 gallon polyethylene tank that enables me to use all of the mixture with very little waste. This drains into the first filter through a ball valve and from there to the DeVllbus PTO pump. This first filter assembly also has a large drain opening to remove the fine screened filter for cleaning and draining the whole system (it’ the lowest point).
The PTO has a metal extension bolted to it that hits the swinging drawbar so the pump itself doesn’t rotate ( see insert, 2nd photo). The PTO pump out-put goes to the pressure control valve that circulates and continuously mixes the solution until the on-off lever is put to the vertical (on) and diverts the flow to the boom or to a hose with a wand for hand spraying. The outflow is a simple garden hose ‘ Y ’with little ball valves that you can’t see on the other side. The outflow to the boom goes through a 2nd filter.
The boom is hinged to fold up as shown and also ‘break away’ if the end of the boom hits an obstacle. A third set of filters are integrated with each nozzle. The reason I got so many filter is the ‘gathering tank’ was made from a fire extinguisher and rusts .Cleanliness is a must with spraying . I’d get a stainless steel or plastic tank if I had it to do over.
It will spray 2 and half acres and a 50 or so gallon tank would be a little handier. I use ammonia to clean it up and then fill the PTO pump with motor oil to prevent it from seizing over winter. The hose and hand wand feature aren’t used much except for things you can drive up to and do from the seat, otherwise you need a second person. I usually spray around 6:00 am when there is little wind and plant later the same day with the tree planter. I’m going to take some photos of the tree planter in a few days. My 17 year old son, Cy, did all the graphics on Adobe PhotoShop from a Canon Powershot S 100 digital camera
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 04/28/01 02:11 PM (server time).</FONT></P>
/ Sprayer
Re: Sprayer *DELETED*
Post deleted by Rch
/ Sprayer #4
Rch,
Its not you, its the server. It is not set up to take photos yet.
Von
/ Sprayer
Von, thanks. It was driving us nuts ! Picture available by clicking on the Fortune City link above. A little later- link doesn't work but you can cut & paste !
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 04/28/01 01:39 PM (server time).</FONT></P>
/ Sprayer
/ Sprayer #7
Ray, I am extremely impressed with your post for several reasons. This is in no particular order:
- That you have the ingenuity to build a sprayer, a well made sprayer at that. Great work
- That you took the time to build your own sprayer instead of going out and spending a lot of money for one...like I did.
- That Cy is able to do pictures and explanations that well. I have been wanting to go digital but don't even know where to begin.
Geat post.
Bill Cook
/ Sprayer
Bill C, as they say, flattery will get you everywhere ! The cost ended up around $700, not much different than if I had brought a high-end one. It wouldn't had all the bells and whistles though.
Cy picked up the Adobe PhotoShop editing skills working on the high school yearbook- removing a zit here, a sweaty armpit there etc.
RCH
/ Sprayer #9
Rch -
I've almost talked myself out of the need for a spray rig, at least for this year, but I do admire what you've done there. And you can tell Cy he did a first-rate job with the photo work! /w3tcompact/icons/cool.gif
Looking at your pictures, I just about want one again, yet at the same time I can see where it would make more sense if I had more unobstructed flat area to spray. Can you adjust to spray left, right or center? Looks great!
BTW -- is that really Kris Kringle leaning on your rig? /w3tcompact/icons/wink.gif
/ Sprayer
Harv, I shut off the left and/or right side by clamping the hose with a Vise-Grip. Re Kris Kringle; first you believe in Santa, then you don,t. Then you ARE Santa !
Good day in central WI, planted 2000 trees today. Photos to follow. I hope Muhammad gets photo thing fixed.<P ID="edit"><FONT SIZE=-1>Edited by Rch on 04/29/01 08:16 PM (server time).</FONT></P>
/ Sprayer
The pump and valves are Delavan, not Devilbus.
RCH
/ Sprayer #12
You did make me wonder about that one, RCH. I'm quite familiar with DeVilbiss air compressors and tools, but didn't know they were into hydraulic valves./w3tcompact/icons/wink.gif
Bird
/ Sprayer #13
good lookin sprayer set-up; we have a local sprayer manufacturer here, with some pretty good prices, but yours looks better than anything i've looked at. i don't use a boom sprayer as much any more, i use a single spray nozzle that gives me more width than the boom did, and i can get a lot closer to the fence rows; BUT, there has to be NO wind. i go back to the boom when i need more control.
good job on your sprayer.
heehaw
/ Sprayer #14
No wind is the key!!! I've also got the single nozzle and it gives me a 30ft spread... unless there is a breeze and then no tell'n what you get. I'm going back to the manufacturer to see if he has a retro-fit kit to replace the single nozzle with a folding boom. The wind seems to never quit blowing where I live /w3tcompact/icons/frown.gif
FarmerBob
/ Sprayer #15
Great Pics.....when do you start doing custom work with the sprayer and tree planter??
/ Sprayer
Actually, custom work is on the agenda. Tree planting of seedlings is an eight month project and most people don't realize the preparation needed for a good outcome. Ideally, in september ( this is for central Wisconsin) I like a hay field that's been cut short. In May, I spray with Round-up just as the clover/timothy is starting to take off ( you need a growing green plant for Round-up to work) but not so tall that a Round-up laden plant touches a newly planted green conifer seedling and kills it( with decidous "whips" that's not a problem). I usually spray 4 to 24 hours prior to planting- they reccomend spraying 7 to 10 DAYS before planting but I find that impracticle unless I'm planting into tall vegetation. I tried fall plowing but it's hard to get in the field early May because of poor footing and get the seedlings started at the front-end of that all important first season. One year I hit everything right only to have a more late appearing weed(morning glorys) choke out the trees. There are sprays that can be sprayed over the top but by planting a mix of conifers and decidous that precludes that.
You have to line up your trees in the Fall for spring delivery. Generally, you want the biggest seedlings you can get( 2 year transplants decidous, 3 year transplants conifers). For example, I ordered 1000 white oak 2 yr transplants ,$330; 1000 green ash 2yr transplants,$330; and 1000 white pine 3yr transplants,$150 from the Wisc. DNR Griffith Nursery at Wisconsin Rapids the firdt weekend in Oct to be picked-up April 27, 01. For each species you have to list a couple of preferences ( white/ red oak; white/ green ash; white spruce/ pine). If you buy from a private nursery you got make sure they are able to come up with the species and AGE of the seedling you want- they have catalogs that look great but can't deliver in the spring. A 1 yr red oak seedling is going to do poorly compared to a 2 yr transplant and it's just as much work for you ! Trees from the state nurseries, especially if you get into various assistence programs have restrictions about not reselling them or not developing the land they're on. Some paper companies sell seedlings ( Trees for Tomorrows, Eagle River WI) that come in a styrofoam container with cells about the size of a test tube and several hundred can be in a block of styrofoam 20 x20". The are handy to store as they have holes in the bottom and can be set in a shallow pan of water for weeks if necessary. They,however, are only 1 yr seedlings and I've had poor survival out in the field. I would reccomend these only for landscapings projects that lend themselves to ongoing watering and weed control for 2 or 3 yrs. Also I've seen these containter plants 1/2 out of the ground the next spring as the ground thaws- they have an artificial soil with peet and vermiculite and literally float out of the ground with surface water. Bare root stock doesn't do that.
I got some nice photos for the tree planting process that my computer savvy kid has to help me scale down and edit for the internet. The big unknown re tree planting is the weather. A local cheese plant has a big drive-in cooler and has stored the seedlings for up to 2 weeks until I can get in the field. Sometimes, the decidous trees will leaf out and a late frost will hit. Some will recover, some wont. A dry July/ Aug is hard on newly planted seedlings since they have little drought resistance. One year, after planting, it turned cold and rainy for 3 weeks and they never took off. Every year is somewhat of a crap shoot. There is a saying; if you want to be happy for a year plant a garden, if you want to be happy for a life time, plant trees. I believe it. There is all that equipment and tractor time, and those trees look better every year.
See " Tree Planter" under Attachments
RCH
RCH
/ Sprayer #17
<font color=blue>if you want to be happy for a year plant a garden, if you want to be happy for a life time, plant trees</font color=blue>
Hey, RCH, at my age I ain't got time to wait on those trees; guess I'll just have to be happy with the garden./w3tcompact/icons/laugh.gif Interesting information (and pictures) though. That's something I've had almost no experience with.
Bird
/ Sprayer #19
Yeah, Scruffy, I understand that. Unfortunately I know too many folks in that shape right now. At least neither you nor my sister-in-law have lost your sense of humor about it./w3tcompact/icons/smile.gif And my mother had a stroke Sunday night; afraid she doesn't have much more time either. But you never know; miraculous recoveries have happened before.
Bird
Unused 2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
2002 Lexus RX 300 SUV (A66738)
2002 Lexus RX 300...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
HOSE REEL FOR TORCH (A64276)
HOSE REEL FOR...
