Sprayer Boom
/ Sprayer Boom #1
Teamjefe
Houston
Kubota M7040
Hey guys,
I'm new here and this is my first post. I own and manage about 4000 acres of land south of Houston,Texas. I have a M7040 that I use for maintenance and small projects. I have a Polaris Ranger that I use as well. I build a spray rig for the ranger that has a 100 gallon tank on a pallet in the bed. I use this for spot spraying mainly. I want to build a spray boom that is about 8 ft long that can attach to my current tank. This will be for spraying food plots and other small areas. I was thinking about using PVC pipe and a quick disconnect so I can change from the spray gun to the bar. Does anyone have any recommendations for what I want to do?
Thanks,
John
/ Sprayer Boom #2
First off, Welcome aboard to forum
They are pretty easy to build and all your supplies can be purchased at any ag store such as TSC. For an 8 foot boom you would probably need about 3 maybe 4 nozzles and overall coverage would probably get you about 10 feet due to the V-shaped spray pattern. A lot of people just T into the supply line and then put a valve on the line to the boom than you can still use your wand sprayer while the boom is still on. A quick connect option after the valve might still be a consideration for you so you can take the boom off when not in use and keep it compact.
Do a search on ebay or google images for sprayer boom. It will give you a lot of different types of homemade low cost boom designs. I bought a low cost 3 nozzle spray boom off ebay for 60 bucks a few years back. If you don't find something you like you should be able to find a design that might suit you best and be able to replicate it.
/ Sprayer Boom #3
pvc will work fine. Agree with super55.
Be sure to engineer it to break away with no damage if you hit a fence post or such. 4000 acres is a lot of land to keep up with. Rice? Manvel area? Rosharon? Sugarland? Needville?
Know of some peeps who switched over from rice to crawdads and apparently are doing OK.
/ Sprayer Boom
Some rice, mainly row crop. Corn, milo, cotton, soybeans.
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
