spot sprayer pump corrosion/protection
/ spot sprayer pump corrosion/protection #1
kossetx
Platinum Member
TX
NH TC 40 A, AC 5020
I spray a lot of roundup, 2-4d, remedy and soon remedy/reclaim mix. I have a 26 gal spot sprayer but continue to use a pump up unit to avoid corrosion because their all plastic. Is corrosion a problem with sureflow pumps used with these chemicals and how do you work to prevent it? I was thinking to rinse it after use and maybe pump some vegtable oil through it afterward. I'm thinking vegtable oil because I may want to use it for something other than killing everything, so petro oil residue may be bad. Will vegtable oil prevent corrosion enough? TIA, MP
/ spot sprayer pump corrosion/protection #3
I think the first thing you need to know is which ShurFlo Pump you're talking about. They make several different ones for different uses.
/ spot sprayer pump corrosion/protection #4
/ spot sprayer pump corrosion/protection #5
Howdy.. am in Central Texas, too.
Now is exactly the right time to spray Reclaim... am getting ready to do that myself... Have used it for several years with extreme success... PM me if you wish details. Reclaim (without Remedy included) in the A&M mix is a superb foliar spray... and is EXTREMELY selective... I've sprayed mesquite with vines in it... and other trees growing in it... mesquite died and vines and other trees bushes didn't even have a brown leaf... truly amazing.
Thus, if you use Reclaim, I would have extremely little concern about residual ... so would simply run a lot of water thru it before the next application.
/ spot sprayer pump corrosion/protection #6
/ spot sprayer pump corrosion/protection #7
Been running gly phosphate and Amine thru a 12v sprayer for years and the only time it gets a good rinse is in the fall with anti freeze.bcs
/ spot sprayer pump corrosion/protection #8
Bird, I just figured that when I stated it was a 26 gal spayer it would be understood that it was either the 1.0 or 1.8 GPM pumps by shurflow, which are built simalarly. I'll be more thorough next time.
/ spot sprayer pump corrosion/protection #11
After using a pump at work, we just run a little water/eco-safe antifreeze mix thru it. It has water pump lube built in.. won't freeze up in the winter, and has corrosion protection.. plus isn't poisoness to animals...
Soundguy
/ spot sprayer pump corrosion/protection #12
Soundguy
John, You spray reclaim W/O remedy on mesquite? I was going to use the brushbusters foliar mix, but I'll I've seen so far is the remedy/reclaim mix. I've just been using the remedy/diesel cut stump method so far and I've cleared thousands of trees.
Dupont is mighty proud of reclaim, aren't they? 187.00/gal
Justaplain, Thant's good to know, thanks!
Soundguy, I never though of eco friendly AF, Thanks a good idea. MP
/ spot sprayer pump corrosion/protection #19
Mark, maybe I should have assumed that it would be one of those two, and I really don't know enough about them. I've had a fair amount of experience with ShurFlo pumps in RVs (12 volt demand systems, potable water only). I also repaired a neighbor's pump on a 25 or 26 gallon spray rig, and I've used my brother's 50 gallon spray rig (both of which were 12 volt bypass systems). But ShurFlo makes so many different ones with pressures from 20 psi to 150 psi, and different models may have Viton, Santoprene, or Geolast diaphragms. Now I don't know all the differences in what chemicals have an effect on those materials. But if I were you, I'd just contact ShurFlo through the web site I posted earlier to be sure. I can tell you that we only flushed them with clean water, whether they were being used for insecticides or herbicides, but there may be a better way.
/ spot sprayer pump corrosion/protection #20
2022 EZ-GO ELITE...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
Tube Line Manure Spreader Nitro 750 (A63688)
Tube Line Manure...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
Massey Ferguson 250 Tractor (A62613)
Massey Ferguson...
