Spool valve
/ Spool valve #1
Lea
Fort Frances Ontario
john Deere model M kabota 2320 TLB
How can you tell which is inlet and outlet on spool valve that isn't marked?
Would the relief be on the inlet side or outlet side?
/ Spool valve #2
Inlet.
/ Spool valve
Do you mean the relief valve is always on the inlet side of the spool valve?
/ Spool valve #4
Yes, typically the relief valve will be in the inlet port of a directional control valve. On bigger fancier valves they can also have work port relief valves built in.
Can you post a couple pictures of the valve in question?
/ Spool valve
Yes I will post some pictures tomorrow
/ Spool valve #6
Ditto on relief valve will be on inlet side.
/ Spool valve
Here are some pictures of valve body in question
For some reason I can not get pictures to upload.
/ Spool valve
Maybe some pic this time
/ Spool valve
On the second pic you notice the lever is in forward position, it only goes the one position and does not reverse and it does not return to centre. I've never seen this before and no idea what it could be used for,, any help would be appreciated
Thanks
/ Spool valve #10
Lea,
The lever only going to two positions would be a detented valve. This holds the valve in which ever position you select. Can be used for running a motor or providing flow to secondary circuit.
Looks like the first 4 sections (left to right) may also have some type of work port feature option. Could be work port reliefs or possibly work port check valves.
Is this an open center or closed center valve?
Any idea what type of machine this was designed for?
With out having the valve in front of me I would suspect that the inlet is on the left while looking at the valve from the handle side.
/ Spool valve
How do you tell if it's open centre or closed
/ Spool valve #12
If you blow air in the inlet does air freely flow out the outlet or tank port?
If yes this would be a open center used with fixed displacement pumps.
If no then it is closed center used with variable volume pumps.
/ Spool valve
Thanks for the answers oldnslo, think I got it figured out now.
Lea
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
2022 CATERPILLAR 259D3 SKID STEER (A64279)
2022 CATERPILLAR...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
