Spool valve float spring corrosion
/ Spool valve float spring corrosion #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
This is a brand new hydraulic spool valve float spring that is terribly corroded. What are the repair options? Can the corrosion be removed; leaving the spring serviceable? Can the spring be replaced? Asking for a friend!
/ Spool valve float spring corrosion #2
If it were me, I would just clean it up. Spay some light oil (WD40?) And wire wheel it. Get it cleaned up the best it can be and reinstall. Try to get the connections water proofed instead of just a butt connection and hoping for the best.
/ Spool valve float spring corrosion #3
Yeah, see what it looks like after a thorough power wire-brushing. If it then shows significant pitting, it may be weakend some.
/ Spool valve float spring corrosion #4
Was the end cap holding water?
Cleanup with solvent left the spring looking great. I didn't need to use a wire brush.
I don't believe that water is the issue; more likely a reaction between the grease and something. The other valve had no issue at all.
This is a brand new tractor, and Yanmar has been working with me to get to the bottom. There is at least one other machine exhibiting the same.
/ Spool valve float spring corrosion #6
I had problems with (just one) loader valve spring when my tractor was brand new. It would freeze in the winter. I finally took the cap off and about 2-3 tablespoons of water ran out. They were made in Brazil, I suspect it was just humid jungle air condensate.
I think I opted to not drill a weep hole, and just replace the air in the cap with ~0% humidity North American winter air. It's been good ever since.
I'd guess Chinese, Korean or Indian air could might be able to that to metal!!
Made in Japan. But I am not sure if the remotes are added there, or here.
Fukushima dried all that moisture! :)
2026 SDlanch SDLE20 (A64127)
2026 SDlanch...
2022 EZ-GO ELITE...
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
Blue Diamond Mini Excavator Brush Cutter (A64126)
Blue Diamond Mini...
2005 Chevy 2500 Pickup Truck (A66408)
2005 Chevy 2500...
