Splitting Large Logs
/ Splitting Large Logs #21
</font><font color="blue" class="small">( I think this baby is going to need the old wedge and sledge routine. Maybe since the center is rotted it will split a little easier. I hope so. My back hurts just looking at that thing.
Makes the L39 look like a little guy. It didn't even phase it though, loping along just above idle....Great machine.
)</font>
I removed a big ash just last fall. Solid all the way through, butt cut at about 30". Worked it up with wedge/sledge plus chainsaw. Also worked up the remains of an old, rotted in center ash year before. Both acted the same, Split nicely (except for the knots) but only after driving wedge well in - down to point 'oh oh, that isn't going to split' point when one more swing and 'pop'. Any knots/crotches got the saw treatment and the big clear rounds also got cut in half befoe wedgeing. While I am one who likes manual work (have a splitter but don't use it), there are times when the power route is the way to go.
Harry K
/ Splitting Large Logs #22
OK I admit not reading the whole thread so if anyone suggested one of these already forgive me. But most of the time one will do the trick sometimes I have had to use two
Wood Grenade
http://undercrank.com/posts/05/01/happy-new-log-splitter
/ Splitting Large Logs #23
IF the rounds are as long as you want them, and the problem is splitting them, all you need is your chainsaw and wedges. A 20 inch bar on your chainsaw will cut 40 inches if you cut on both sides of the round. Use the wedge to pop it apart the rest of the way.
If the rounds are longer than what you want, then use several wedges lengthwise down the log until the log is halfed or quartered. Then use the chainsaw to cut to length. You can cheat by cutting the log lengthwise with the chainsaw on opposite sides, then use the wedges. Don't be afraid to use as many wedges as you need for the job. It may take four or five or more wedges to do the job if the log is long.
Sky...I intend to use a large "eye" lag bolt. For the couple of really big one...I'll lag and lift with the fine hoe and positon perfectly on the splitter /forums/images/graemlins/smile.gif
/ Splitting Large Logs #25
Cut the rounds smaller. If you have them at 24" and cant handle them, slice them in half. If you still cant get it on the splitter they are a heck of a lot eaiser to split thin with a maul. I have done a couple of oaks for my father that were big. And there is a white oak on the property line that needs to come down. My 20in bar probably wont make it, soo this will be my first center bore.
10-12 inch splits will burn as well as 20-24 inch splits, better if you are really packing the stove.
/ Splitting Large Logs #26
Sounds like a good plan but don't get under one while its airborne!
Madman...I just got myself a genuine "Wood Gernade". I asked a few hardware stores they just looked at me funny. Finally found one. Hopefully it'll help this process. I got a couple of standard wedges too.
/ Splitting Large Logs #29
Hey, if you want some advice on the bore cut: Plan your bore cut carefully and then try not to hesitate while cutting. I got my saw stuck in one and had to remove the main assembly from the bar while stuck. Very dangerous. Don't wear hearing protection so you can get a sense of what the tree is gonna do... Good luck, be safe!
/ Splitting Large Logs #30
Jim, those wood grenades are pretty good, but they too can get "stuck". I just lost one (well, really embedded it) in an elm log this am.... It doesn't explode the wood as said, but it's a lot better than the standard splitting wedge...
/ Splitting Large Logs #31
I don't know abot Mass., but the elm around here is very wormy and is difficult to split even with a hydraulic splitter. Kinda rubbery, and the BTU value is low. That said, I've used the grenades on oak, cherry, ash...and they do well. Sometimes will even quarter with one shot.
/ Splitting Large Logs #32
ya, the same in taxachusetts... i burn elm once in awhile it coals OK... gonna split wood all weekend. oak, ash & maple! will use the wood grenade fer sure....
/ Splitting Large Logs #33
Jim, the 359 is a very nice saw. It isnt to big for my use which is pretty much firewood, treetops and clearing, but it isnt to small either. I get a good sharp chain on there and its a wood eraser. The back up 136 is a real nice saw for small stuff and limbing.
My father has a older Husky 61, with a 16 in bar on it. WHOOOOOAAAA NELLIE talk about tourqeing through wood. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Its about 1/2 the lenth bar its rated for. If he ever gives it up I figure on scamming it and putting a 24-28 in bar on for the occasions that I need a bigger saw.
Arthr31.
I looked the oak over this weekend. Its a old pin oak that is freaking huge at the base. I am not sure that I have enough bar even if I bore it. That and the limbs about 35-40 feet up show signs of a lot of rot, from the ground. That = widowmakers. I thought it over and if the neighbors want to tackle it (line tree) I figure on limbing it off a ladder, dropping them strait down, and letting about 30 foot of trunk stand. I MIGHT be able to cut it, but there is no way that I am going to roll those rounds onto or up to a wood splitter. Not worth the effort. Some of the limbs are about 24+ in across so that is a lot of wood in itself.
Told the old man to take the backhoe up and dig a trench on the downhill side near the base and look up the hill and see if it fell about once a month. /forums/images/graemlins/grin.gif It isnt a pretty thing.
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
207281 (A52708)
207281 (A52708)
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2002 Ditch Witch 1230H Walk-Behind Trencher (A61572)
2002 Ditch Witch...
