Split-dovetail car hauler trailer
/ Split-dovetail car hauler trailer #221
Nice work! I always install the tongue jack back a foot or so from where all trailer installers usually put them,(usually in the hole in the Atwood 2 5/16" coupler,) I like to be able to lower the tailgate on my trucks,and be able to back up with the tailgate down,without having to use an extended length receiver .
Thanks. That's a good idea if you have a tailgate.
Jack welded on. I wire brushed the weld area with my grinder before welding it on. Other than the sticker being put on crooked, I like it a lot better.
/ Split-dovetail car hauler trailer #224
Since you put it right up front, you now have room for a winch right behind it. The first winch I mounted to my trailer I put right ahead of the deck area, and found it was too close to the loading area, a lot of vehicles hang over the a-frame area when they are all the way up on the trailer. You can't get a good pull on the vehicle the last couple feet when the vehicle is over top the winch.
So I just got done installing a new 12000lb winch from Harbor Freight, and I mounted it as far up front as I could, without it hanging over the sides where the truck bumper could smash it. Just used it today and it works a lot better up there. I also put a wooden floor in part of the a-frame to have a place for the battery and a little bit of storage for chains and binders.
/ Split-dovetail car hauler trailer #225
Buggyman1, That is a top notch trailer you have built! Thanks for bringing us along for the build. Can't wait to see it loaded up.
Thanks, i'm working on a toolbox for the tongue now. I'm getting close to wrapping this thing up.
I haven't had a lot of free time to work on the trailer lately, but I've got a little bit done on it. I've been working on a toolbox to store straps and chains etc. I decided to box in between the a- frame and make a storage box that will be flush. I boxed it in with 14 gauge sheet, it was kind of tricky to get the cuts right.
I made the lid and bottom out of the left over diamond plate from the deck, I wanted the top strong enough to stand on. I also made a trim piece to kinda bridge the gap between the box and the headache rack.
Storage box 90% complete. Not a ton of room, but should be good enough for straps and chains and a few tools. I'm not going to put a handle or lock on the top, I like the flush look, instead i'm gonna try and install a linear actuator to open the lid. I have one ordered, just not sure when it will get here, should be fun trying to install it. I have one on my dump trailer (to release the tailgate) and it works really well. I plan on hiding the switch (should be fun) that controls it, maybe inside the headache rail...not sure yet, it's also remote controlled. Here's a few pics of how it looks now.
Pulled the trailer out of the shop, it was a close fit.
Here she is, less paint and a few other things. I pulled it down the road a few miles to see how it towed, was real happy with it. It seems a lot lighter than my dump trailer.
Loaded up, I didn't use the rear jack and the truck did fine. That's a Toyota Camry (if you can't tell), I had about 4 inches clearance between the door and fender. I decided to paint it myself with the help of another poster on another site ( thanks farmersamm). He did a full how-to paint thread for me on weldingweb, thanks again samm. I hope to get started painting sometime this week.
/ Split-dovetail car hauler trailer #233
Looks very nice. I like it a lot!
I finally got my linear actuator in and installed. I made two brackets for it and welded them on. It was kind of a pain getting everything to work in an enclosed space but I finally made it work.
I've been making and welding on wire looms out of square tubing.
I also bought a paint gun to paint this beast with, hope to get started sometime this week.
/ Split-dovetail car hauler trailer #237
attachment.php
That is awesome! :thumbsup:
I have never seen a powered storage box lid.
Thanks, I really didn't need it, but its cool to watch it in action.
/ Split-dovetail car hauler trailer #239
When you welded on the spring mounts and the tongue, how did you square everything up? You said it tows nicely so that's a good sign that it tracks straight down the road. I'm thinking of building a trailer one day, and have been curious how precise the axle location needs to be?
Very nice build, btw.
I measured the same distance from both sides and also used a square. I used a string to center-up the tongue, I think there is a pic of that in an earlier post.
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
Location Info Please
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
(INOP) 2012 FREIGHTLINER CASCADIA DBL SLEEPER ROAD (A60430)
(INOP) 2012...
