Spend my money.
/ Spend my money.
I already know what a Kubota L4240 with a 6ft bushhog will do on steep ground. You can try it and we will decide what you think when you hit the bottom, either on its wheels or on its top. I dont hold out much hope for the L3200 either.
The primary factor influencing tractor stability is the spread/stance of the rear wheels/tires. The Kubota L4240 has rear tire/wheel spread adjustment of 12" as a standard feature with both R1/ag or R4/industrial tires. Did you set the wheels wide on the L4240?
The second factor is wheel ballast. Loading tires 50% to 75% with ballast improves tractor stability by lowering the center-of-gravity. Were the L4240 rear wheels ballasted with liquid or wheel weights?
Third stability factor is ground clearance. Less ground clearance is better than more for stability. R1/ag tires increase ground clearance over R4/industrial tires.
What tires did you have on the L4240?
The Three Point Hitch tractor has been marketed in the USA since 1939. Patents on the Three Point Hitch and TPH hydraulic controls expired in 1955. Since 1955 (66 years) all traditional compact tractors have been designed and produced around the Ferguson Three Point Hitch, worldwide.
The Three Point Hitch tractor design is generic.
When T-B-N correspondents correlate any TPH tractor brand directly with stability it invites skepticism.
Best tractors I have found for wood work are the older Massy Ferguson models, (235, 245's). It just seems to me they are more stable and heavier weight wise.
Ground clearance of MF245 (1976-1983) is 9.4 inches.
Weight, diesel, 4,050 pounds bare tractor.
Width 71"
I dont know the details on the l4240, it was a borrowed tractor. It did have ag tires and they where fluid filled. About all I can say about that. I didnt know the weight of the mf 245, but the low ground clearance and weight sort of explains the pulling ability. Just a little more comparison info to help in my search.
I have ran farm tractors skidding logs since the late 1960's, early 1970's. Not commercial logging, persi, but we cut 5ft pulpwood until I went to work for the railroad in 1976. I am no stranger to running a tractor, I just dont know anything about this new stuff. I want HST because of a metal knee. I want a tractor to mow and maintain the field on the farm. A loader for loading logs on a bandsaw mill and moving lumber, a scrape to maintain my driveway and a tiller to work a garden. Most any tractor will do those things, some just better than others. I dont like JD or Kubota, I have my reasons and enough said about that.
/ Spend my money. #22
IMHO John Deere & Kubota are the most
expensive tractors plus the options which
are standard on other tractors will cost you
a heap of dough!
Your best bet is to try all the tractors you can
so you can get the feel of what you want and
is the tractor going to be easy to operate as
are the controls easy to reach operate etc.
Everyone has an opinion on which is the
best tractor but you have to decide which is
the best one to fit your needs. You will get
a lot of good advice from the guys here however
its going to be your tractor so you need to test
drive all the tractors you can to make a decision
because you are the one that will be using it!
willy
/ Spend my money. #23
Width 71"
I don't like itybitty tires on the front, but I don't need a set of super swampers either.
Kubota M5660SU Dimensions​
Dimensions
2WD Wheelbase:82 inches
208 cm
4WD Wheelbase:80.7 inches
204 cm
2WD Length:138.7 inches
352 cm
4WD Length:136 inches
345 cm
Width:73.2 inches
185 cm *
Height (ROPS):95.3 inches
242 cm
2WD Weight:4189 lbs
1900 kg
4WD Weight:4387 lbs
1989 kg
Ground clearance:16.3 inches
41 cm
2WD Front tread:55.9/71.7 inches
141/182 cm
4WD Front tread:51.2/55.1 inches
130/139 cm
Rear tread:52/67.7 inches
132/171 cm
Page information
Last update:June 9, 2021
Copyright:Copyright 2021 TractorData LLC
Contact:Peter@TractorData.com
Kubota LA1154 Loader
Height (to pin):132.7 inches
337 cm
117.2 inches
297 cm (power position)
Clearance, dumped bucket:101.5 inches
257 cm
85.5 inches
217 cm (power position)
Dump reach:18 inches
45 cm
35.9 inches
91 cm (power position)
Dump angle:43°
60°
(power position)
Reach at ground:76.7 inches
194 cm
Rollback angle:43°
Lift to full height (at pin):2469 lbs
1119 kg
2928 lbs
1328 kg (power position)
Bucket width:72 inches
182 cm
Raise time to height:4.7 s
Bucket dump time:2.8 s
Lowering time:3.6 s
Rollback time:3.0 s
/ Spend my money. #24
The other thing to consider is whose engine, and the parts availability for it.. Go on eBay and look for parts to fit the engine.
Talk to local independent tractor repair shops, most rural towns have at least one. They will have experience repairing multiple brands and models. And, in sourcing parts for them. They don’t have a vested interest in any of the brands, and will generally give you the straight scoop on which one they would buy.
/ Spend my money. #25
Anyone not familiar with the HST transmission should know that just like the other popular transmissions like GST or other Powershifts, the more transmission ranges you have on a tractor the better it is.
Kubota's HST+ tranny has six ranges - it's real handy and gets used everyday. Extra ranges sure do make the tractor work better. The HST+ is a Kubota option, but has been out since 2007, so I imagine most other makes offer a similar upgraded transmission.
/ Spend my money. #27
I’m not here to bash any tractor manufacturer, I’ll discount my advice from $.02 to free.
I bought a new Branson 3510 in 2004, it’s been a great tractor until this July 2021(thread about it in the Brandon/century section)
I lost hydraulics in early July, and with help from this forum I was able to dive into repairs on my own. The hydraulic drive gear inner spline was wiped out, this gear drives the hydraulic pump.
My first parts order from my local dealer, (that no longer sells Branson tractors, but will repair and order parts) were wrong, wrong gear, bearings and hydraulic pump. It took several calls to Branson to hopefully get the correct parts ordered, the gear however has to come from Korea and could be months, as of today 8-27-2021 I’m still waiting almost two months later.
cost of parts will be over $1200 ( Gear, bearing, hydraulic pump, bearing housing and two gaskets).
This lead me to decide I will not keep the tractor after it’s repaired.
I decided the Kubota L3901 was the right tractor with dealership support for me. Yes I paid more for the brand name
but I’m getting too old to worry about the Branson breaking down again and poor support (at least in my area), or if I will be able to get the parts I need in a timely manor.
Wednesday my new tractor was delivered, I was told 4-6 weeks, it took less than two.
My dealership has seven branches (Jacobi Sales), I recommend only buying a Tractor from a dealership you think will be around to support your needs for a long time.
Mike
/ Spend my money. #28
... I want HST because of a metal knee. ...
A point to consider that you may or may not have thought about - there are 2 pedal types that I have seen on HST tractors. One is a single pedal (like a treadle) that you rock forward to go forward and rock back to go in reverse. The other is two separate pedals side-by-side, the leftmost one to go forward and the right-most one to go in reverse. You will want to make sure that the position you need to get your foot into isn't going to cause you discomfort if that metal knee is in your right leg.
I am a new tractor owner, just reaching 50 hours with my Kioti KD5310SE. It has the side-by-side pedals and I find them more comfortable to use than a single treadle pedal. YMMV.
/ Spend my money.
Been away since my last post. 45th year wedding anniverary and, well you can guess the rest of the story.
Anyways, at least one person seems to agree with my thoughts on the JD and Kubota tractors. As for a dealer close to me. Nearest ones I know of are both out of state and they carry the exact same brands, Kubota and New Holland. They did carry JD, but with the new Agco dealerships JD stripped them of being able to sell them. Actually there is a new agco dealership just down the road from me, they dont have hardly anything in stock and I aint likely to go looking. I dont look for them to stay in business long. There just isnt much big farms close and there main customer will probably be someone like me just looking for a garden tractor. I have been searching dealer and auctions, got my eye on a Massey 2605 with cab and loader, sycro trans. A little bigger than I was looking for but current bid is $17000 and it is in My state, altho on the other end of the state. I still havent looked at any Yanmar's, actually havent even looked for a Yanmar dealer yet. But Yanmar has made my short list. I was told there is a Kioti dealer about 75 miles away and I might make the trip just to see what they got. In fact, the nearest massey dealer is in the same area so I might kill two birds with one stone.
/ Spend my money. #30
Massey Ferguson 26053​
Massey Ferguson 2605 tractor photo
2007 - 2018
2600 Series
Utility tractor
TAFE built
Series:2605
Production
Distributor:Massey Ferguson (a part of AGCO)
Manufacturer:TAFE / India
Type:Compact Utility tractor
Original price:$13,166 (2009 )
Massey Ferguson 2605 Power
Engine (gross):38 hp
28.3 kW
PTO (claimed):32 hp
23.9 kW (live)
Dimensions
2WD Wheelbase:76 inches
193 cm
4WD Wheelbase:77 inches
195 cm
Length:129 inches
327 cm (2WD)
130 inches
330 cm (4WD)
Height (ROPS):92 inches
233 cm
2WD Shiping weight:4080 lbs
1850 kg
4WD Shiping weight:4530 lbs
2054 kg
Clearance (drawbar):10 inches
25 cm
Transmission:CenterShift
Gears:8 forward and 2 reverse
Clutch:dry disc
Four gears, plus reverse, with high and low ranges
Massey Ferguson DL250 (4WD) Loader
Height (to pin):123 inches
312 cm
Breakout force (lift):2,747 lbs
1246 kg
Lift to full height (at pin):2,952 lbs
1339 kg
Lift to full height (at 800mm):1,780 lbs
807 kg
No width shown.
/ Spend my money.
Jeff, dont know where you are getting your charts, but the numbers dont seem to matchup with the advertisements.
Massey 2605h
3-Point Hitch
Rear typeII/I
Control-
Rear lift2755 lbs [1249 kg]
Front hitch-
Front lift-
Power Take-off (PTO):
Rear PTOlive
Clutch-
Rear RPM540 (1.375)
Front PTO-
Engine RPM-
Capacity
Fuel14.5 gal [54.9 L]
Dimensions & Tires
Wheelbase80.7 inches [204 cm]
Weight4894 to 5394 pounds
Front tire6.00x16
Rear tire13.6x28
Massey Ferguson 2605H Power:
Engine gross55 hp [41.0 kW]
Engine max-
Mechanical
Chassis4x2 2WD
Differential lockmechanical rear
Steeringpower
Brakeswet disc
Trailer brakes-
CabTwo-post folding ROPS.
/ Spend my money. #32
I can see it now, a ford 1210 with a loader with 2000lb pallet of fertilizer on the front. No thank you. And I already know what a L4240 with a 6ft bushhog will do on steep ground. You can try it and we will decide what you think about it when you hit the bottom, either on its wheels or on its top. I dont hold out much hope for the L3200 either. I had better luck on the same hill side with a 4610su, 2 wheel drive, than the l4240. There is a reason I dont consider kubota when it comes to tractors to go in the wood with. Yes, I know a lot of folks own them and like them, but my experience tells me to stay far away. Best tractor I have found for wood work ( I probably should have mentioned small logging as work to be done, is actually the Massy Ferguson, older models, (235, 245's). It just seems to me they are more stable and heavier weight wise, and have more actual pulling power when dragging a heavy load. I dont know if that holds true to the newer ones being sold now. I dont know if they ever made a 245 with 4x4, but if they did, I would be looking for one. I dont need the latest bells and whistles. I appreciate the suggestions, but those are not the tractors I would consider.
MF 245/L4240/4610 : from Ops manual (parenthesis is Tractor data.com)
Wheelbase 73 1/8" (74.5") (74.6") (71.5")
Overall length 116" (126.5") (121.5") (117.5")
Width overall 70" (71") (66.5") (62.4")
ground Clearance 9 3/4" (9.3") (14.6") (15.0")
Wheel Tread Front 48" to 72" (48" to 80") (51.2") (50.8")
Wheel Tread Rear not defined (56 to 76") (50.6 to 60.2") (46.5 to 60.8")
weight (4000 to 6000 with ballast) (3500 to 4000) (3200)
w/o ballast w/0 ballast
Just comparing these machines does some validation of experience over specs when it comes to someone like Muddstopper who has enough experience that he doesn't seem to need to spout specifications over the way he feels a machine behaves on a slope.
Ground clearance alone, while it doesn't show the height of the Center of gravity of the MF, it does show that the MF could be a whopping 5 to 6 inches lower to the ground than the 4240 or 4610. Add to that the wider stance of 70" vs 63 or 64", and you get the two main constructs that can determine stability (barring a Cab...). We don't however know if the Ground clearance measurements are directly comparable.
  • overall specs massey-ferguson-245-tractor-operators-manual.pdf
/ Spend my money. #33
Width 71"
I saw this after I posted my comments... we are on track here! I agree other than Ground Clearance.... its the Center of gravity (mass) that determines this point. IMO, and to take it to extremes to prove the point... you could have a tractor that is 3" off the ground but have a weighted height that could overcome that low ground clearance benefit. Great post!!
/ Spend my money. #34
Perfect - Great comments from experience, there is nothing better in my book!
/ Spend my money. #35
Maybe @jeff9366 should revise the text to read:
"The primary factor influencing tractor stability is the spread/stance of the rear wheels/tires... relative to the center of gravity"
Great thread, lots to learn here.
/ Spend my money. #36
After looking up these numbers I decided check out the comparison for my L3650 HSTC with Cab.
--------------------------------MF 245 ------------- L4240 ------------ L4610--------L3560 Cab
Wheelbase ..................73 1/8" (74.5") ............(74.6") ..............(71.5")..........(71.1")
Overall length..............116" (126.5") ...............(121.5") ...........(117.5")..........(115")
Width overall ...............70" (71") ....................(66.5") ............(62.4").............(59.8")
ground Clearance ........9 3/4" (9.3") ................(14.6") ............(15.0").............(13.5")
Wheel Tread Front .......48" to 72" ....................(48" to 80") .....(51.2") (50.8")..(45.5")
Wheel Tread Rear ....... (56 to 76") ...................(50.6 to 60.2") ..(46.5 to 60.8").(58.3")
weight............(4000 to 6000 with ballast) ........(3500 to 4000) ..(3200).............(3900)
It's interesting to note that most if not all of the weight difference in the L3560 between cab and non cab models is 400 to 500 Lbs. the further away from the CG of the tractor that weight is, the less stable it is.
In the case of the Cab tractor and 500 lbs of that additional weight being up, say about 2 to 3 feet above the Center of Gravity of the mass, there is definitely not a lot of margin for error. The cab height is 91". That's 7 feet of a decreasing value of that 500 lbs acting against tractor stability depending on the point of measurement. And the width of the L3560 is the narrowest of all of those listed at only 59" overall.
If there is any question on whether your requirements dictate stability over comfort or anything else related to CAB functionality, the option of an open station would probably beat out the stability of a cab model much more than not.
/ Spend my money. #37
Its interesting that I have not seen anything to state the CG of any of this equipment. I can understand why though.
Lets say you sell implements and you want to design a front boom articulated mower that will reach at heights of 12 feet or more, or reach into a ditch or pond lower than the tractor out 4 to 8 feet...
If you then relied on anything from the manufacturer related to CG, well, depending on how the user loads his equipment or not, that CG could be off enough to make adding what might be a "safely designed" piece of equipment dangerously lacking in a margin of safety to prevent a rollover. Its just crazy how quickly weight above the CG can change depending on the height something is placed. A pair of 125lb chains hung at 3 feet have a directly increasing load against overall stability for every foot it is above the CG. Everybody adds lights, radios, maybe a cooler (with ice), some tools in a tool box mounted at 4 to 5 feet. I have seen folks on Youtube videos ride with two adults in a cab meant for 1. Not saying that someone is going to hit a steep incline when doing that, but what does a 175lb persons weight at 3 feet above the CG do for stability in a Cab unit that's already top heavy AND a pair of chains? I haven't calculated the answer but we probably could.
Could that situation decrease stability by 25% ? 45% ? or 60% in a cab model ? ... I'm afraid that we will find out all too soon as more and more folks make the switch to cabs as a "general use tractor" and not simply for snow blowing or mowing. Add to that Folks being given more and more options for universal front end attachments that increase functionality at the cost of stability without adding back in the safety margin that ballast may or may not be able to overcome.
What are your thoughts?
/ Spend my money. #38
Mike
Mike,
Thank you soooo much for the discount. But, I'll still need a receipt showing the discount for tax purposes if you could please?
2016 FREIGHTLINER CASCADIA 125 T/A DAYCAB TRACTOR TRUCK (A59912)
2016 FREIGHTLINER...
UNUSED X-STAR 101"x25' BRIDGE PLATFORM (A64280)
UNUSED X-STAR...
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
(5) 2" X 20' STEEL PIPE (A64281)
(5) 2" X 20' STEEL...
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
