Speedy Highway Construction
/ Speedy Highway Construction #2
Time will tell... Especially on the areas that was a deeper compacted fill over a culvert, or up agaisnt a bridge backwall. It may show up immediatley, or 5-10 years down the road, but it will show. Almost bet they are working 24-7 to move that much dirt..!!
LUV running those scrapers..!!
They finished it in July. They had 17 months only took them 10.
/ Speedy Highway Construction #4
Were they within budget on the completion? When projects finish early, it's normally associated with also being under budget too. These contractors really deserve their bonuses/incentives when that happens.
Do you have a link to any of the finished project photos? Is the road surface concrete or asphalt?
/ Speedy Highway Construction #5
Whoever figures the time strutcher out should never do it again. Hope the bridges don't fall down.
It will not let me post a link to the completion article here is title Toyota plant brings Highway 9 to record completion
Asphalt-bridges per cast- Under budget-
Contractor got $50,000 a day to finish early.
/ Speedy Highway Construction #7
Here's another article with a photo. I'd bet Toyota isn't too crazy about this photo because the white car pictured is a Honda, I think.:rolleyes:
Another photo I found:
/ Speedy Highway Construction #8
Of course one thing to take into account is that the labor market in this neck of the woods had TANKED, it was up around 11%. Workers were probably easy to find.
/ Speedy Highway Construction #9
And cheap too.
At 11%, I'd bet alot of them were quite hungry.
/ Speedy Highway Construction #10
I think the contractor said that they had everything in place as far as materials too. They didn't have go through a buying/delivery cycle. I'm also certain that the geography of the area had a lot to do with speed. The same stretch of highway in West Va. or the Ozarks in Arkansas would have been much slower because of the huge amount of excavation.
One thing they are doing in Texas now is build an asphalt road first and then put concrete on top of it. The old roads here were built with concrete right on top of the compacted ground after treating with lime. I can remember working for the Texas Highway Dept in the summer and measuring the concrete slab at exactly 9" think. We thought that was very thick, but many of those roads heaved and moved from the clay soil under the base. Now they do much more excavation and fill with road base materials followed by asphalt that looks like a very nice highway. But, they immediately come back and pour a concrete slab that looks to be at least 12" thick on top and continuous with expansion relief cuts made in the top surface. These roads seem to stay flat longer and have much less maintenance. Now there are many state highways and farm to market roads in Texas that are asphalt and extremely nice flat surfaces that don't "sing" as you drive across them like much of the grooved concrete.
Contractor has built several roads in the state and is working on a few right now. He has plenty of people and equipment to do a job. Having GPS on every machine speeds up a job also. The roads that they have built usually hold up really well. New construction with the money already in place for the project don't take as long. Most of the time we build a little bit at a time as money is approved by state. The money was only approved because the road was promised to Toyota when they opened the new plant on the thousand or so acres Mississippi gave them to come here. Toyota had to have 4 4-lane routes within so many miles with train line to come here. They want to be able to move stuff in and out quickly. They use a just in time (no warehousing system). About ten support plants employing 400 or so employees each surround the main plant with 15 miles. Millions and millions were spent on infrastructure Including upgrading the main highway it sits beside to a interstate. A whole lot of tax money for one company to employ a few thousand.
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Mini Universal Wheel Barrow (A65640)
Mini Universal...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
