Specialize in tracked vehicles
/ Specialize in tracked vehicles #1
Northern Minnesota
Massey Ferguson MF34
I sell parts and service for Bombardier, Nodwell, Gotrack, Flextrack, Softrack, ASV, clark components, and others. I'm rebuilding my brothers bucket and lift cylinders on Massey Ferguson MF34. Is there an easy way to start the retaining rings out of the access removal hole. The glands don't seem to want to turn and I don't want to damage them. From what I understand when you turn the gland you start the retaining ring out of the hole and rotate one full turn for removal. Is there a trick? Or are they normally stubborn and need a bigger hammer?
/ Specialize in tracked vehicles #3
Welcome....
The trick IS to turn them......freeing them up can be the tough thing sometimes...keep working at it to loosen....(heat/lube/heat/lube)
/ Specialize in tracked vehicles #4
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Massey Ferguson Owning/Operating Forum. You'll get a better response there. ;)
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
2012 Mini Cooper Hatchback (A64557)
2012 Mini Cooper...
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
ALUMINUM CUTTING BOARD, (2) POLY CUTTING BOARDS (A64278)
ALUMINUM CUTTING...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
