Spare 15 fuse in #1 slot on Bobcat CT 235 fuse pannel
   / Spare 15 fuse in #1 slot on Bobcat CT 235 fuse pannel #1
powerscol
SW Colorado
CT 235
Has anyone used this fuse and is the wiring there. Picture is on PM-34. Just wondering before I try and pull the block to find out. I'm looking for a 15 amp hot with switch on. Also there is a pigtail at the rear that my work light plugs into. Anyone know what fuse it uses. If not Ill pull the fuses one by one to find out. I am a bumble finger guy and hope not to screw up the wiring.
Thanks
   / Spare 15 fuse in #1 slot on Bobcat CT 235 fuse pannel #2
I am slow, where or what is PM-34? I have a manual showing fuses and what they control but don't know which fuse you are referring too.
PM 43 is the page in the owners manual. Its the first fuse at the top of the fuse block to the right and under the throttle behind the break and cruse handles. #1 15 AMP is listed as a spare in the block.
   / Spare 15 fuse in #1 slot on Bobcat CT 235 fuse pannel #4
I don't have a copy of the owners manual. My testing with volt meter shows no power going into that top fuse location. No wires going in or out of the fuse rear. I have installed a rear work light on my tractor I think using the pigtail you are referring too. It uses the second fuse down, working lights and brake lights.
Thank you sir. Was a bit under the weather today, so this is a big help
   / Spare 15 fuse in #1 slot on Bobcat CT 235 fuse pannel #6
I used that fuse for lights on the snowblower and I just jumpered a hot wire from the headlights to that fuse and ran it through a waterproof toggle to the snowblower.
Lockport
I can not thank you enough. :D:thumbsup::cool2: Today I did as you suggested and made the spare circuit live. Tomorrow I will post pictures of what I did so folks know.
Thanks again - Keith
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
Portable Restroom (A54865)
Portable Restroom...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
