Source for diesel inline fuel filter
   / Source for diesel inline fuel filter #1
Mighty Dodge
The Hereford Zone, MD
JD 4200
Anybody know of a good inline fuel filter. I'm re-powering a garden tractor with a Lombardini diesel. There isn't room for a large filter and was hoping to use an inline suitable for diesel. The original Lombardini specs call for a 5 micron filter.
Thanx
M.D.
   / Source for diesel inline fuel filter #2
What size hose are you running? I can look one up for you in a Fleetguard or Donaldson catalog but need to know what size hose you are running.
   / Source for diesel inline fuel filter #4
A Fleetguard FF5480 is a fuel filter for a ONAN engine and has a .26 inch inlet and outlet.
If you want a metal housed filter try a Fleetguard FF5066 (Fram G1), it is a true 1/4 inch inlet/outlet filter. This is probably the best for your application as it is intended for diesel engines and is a factory filter on BOBCAT'S with WISCONSIN, KOHLER, ONAN and DEUTZ AG diesel engines.
Thanx alot for the info!
I'll pick one up tomorrow and take it for a test drive.:D
Tried a G1, it won't flow enough, must need a fuel pump. I need something for gravity feed. I'll keep searching.
M.D.
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2020 KUBOTA RTV...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
