Loader sounds like cavitation
/ sounds like cavitation #1
dsc csd
new market,tn
656D IH and 656 farmall
just purchased 656 farmall with cab and loader. everytime it starts it makes a whining noise which seems to be coming from the hydraulics. it stops in about 10 to 15 sceonds and then seems to be fine. wondering if its in the pump itself or a seal?
/ sounds like cavitation #2
Not really sure,but if the seal was going bad wouldn't there be signs of leak?...maybe early signs pump its self going bad...bearings.
/ sounds like cavitation #3
Welcome to TBN...........
Since you just purchased it, when was the last time the filters and fluids were changed.
Fluid level could also be low.
/ sounds like cavitation #4
If it's a high frequency squeal, the pump is most likely sucking air. It's bit hard to cavitate oil in a gear pump. is your fluid level low?
changed all fluids and filters first thing, everything seems to operate as it should. fluid is a little below full mark by a quarter inch. didnt think that would be low enough to hurt anything
/ sounds like cavitation #6
Having the oil a little bit low should not cause a pump to suck air. A loose or cracked pick up tube will however. The fact that it goes away tell me the pump loses prime after the tractor is shut down and regains it on start up after 15 seconds. It's probably a small air leak and I 'd still suspect the pickup device. It's nut critical since it regains its prime but its something to monitor over time to see if it worsens an then you'll have to take some action. How difficult is it to get to?
havent had a chance to check it out yet jerry/mt. will dive into the old shop manual when i come off of rotation at the mines. i had had the thought that could be a possibility as well. being fairly new with internationals i havent experienced working on the hydraulics yet.
/ sounds like cavitation #8
There are yanmar models that lose prime on sitting. The hydraulics don't necessarily whine on startup, but there is a delay in hydraulics. My thoughts would be that it is not critical if there is a few seconds of whine and then no issues whatsoever. I would fill it right up to full and see how that goes, and continue troubleshooting, but don't lose sleep over a few seconds of whining.
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
2018 Chevrolet Silverado 3500 Royal Service Truck (A64194)
2018 Chevrolet...
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
(5) Round Grass Hay Bales (A66408)
(5) Round Grass...
Rustic Pine Bench (A66408)
Rustic Pine Bench...
Groundsmaster Mower (A64194)
Groundsmaster...
