Some PT-425 videos
   / Some PT-425 videos
kmaz said:
Hey kent, i didnt anticipate it working as smoothly as it does either. The key is precise placement of the drilled and tapped hole. The threaded star knob is just shy of touching the steel block mounted on the underside of the joystick when its not being used. When you want to lock yourself in float simply push the joystick to float , turn knob a half turn and it cant come out of float because theres a bolt in the way.
Kris
Thanks, Kris! :) I'll have to look closely and see if I can determine how to locate a threaded knob. I have a knob, if I can figure out exactly where to put it...
2019 Peterbilt 579 SLEEPER (A59905)
2019 Peterbilt 579...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A59904)
2003 VOLVO VNL...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
(18) 10'-6" PVC CONDUIT PIPES (A60432)
(18) 10'-6" PVC...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
