Some BX Rock/Thumb work.
/ Some BX Rock/Thumb work. #1
Singlecoil
Eatonville, Washington
Kubota BX-24D Cub Cadet LT42e
I'm finally getting the swing of the new thumb.
I dug out several rocks this size...
Then this rock I was able to lift out of the hole, but the boom wouldn't budge when I tried to lift it. I was able to drag it about 10 feet; the tractor had it almost off the ground. I then picked it up with the FEL and it was straining to lift it. It must have been in the 500-600 pound range.
/ Some BX Rock/Thumb work. #2
Yeah you would definitely notice that one in your shoe...
Thumbs are awesome. Glad to see your BX is no worse for wear and that you're back in business. Try to keep it on all 4 tires this time 'round :)
Yeah, from the pictures you would think I was trying to roll it the other way: end to end!
/ Some BX Rock/Thumb work. #4
You want to be carefull draging anything with the back hoe as there is no pressure relief valve on the cylinders. Wouldn't take much to bend a cylinder rod or dipper arm.
ron
ron
Roger that. Thanks.
/ Some BX Rock/Thumb work. #6
Looks like my Daushund trying to sneak off with a cow leg bone. :D
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
ALUMINUM HYDRAULIC TANK (A68842)
ALUMINUM HYDRAULIC...
10ft Fork Extensions (A66734)
10ft Fork...
master diesel generator (A64553)
master diesel...
2016 Nissan Sentra Sedan. (A66738)
2016 Nissan Sentra...
AIR HAMMER (A64553)
AIR HAMMER (A64553)
