Solid state drives not reliable
/ Solid state drives not reliable #1
Alan L.
Elite Member
Grayson County, TX
Kubota B2710
Got 5 new dell computers and replaced the hard drives with SSD drives from crucial. In 6 weeks two have totally failed and one is iffy. Replaced one with an intel SSd so far so good, replacing another with intel today. These are very fast but very disappointed in the reliability. Thank God for Symantec system recovery. These are 512gb drives. The Intels are 480.
/ Solid state drives not reliable #2
I have just recently heard about these as I am not up on new technology like I was. This is good to know, though I actually expected the opposite. If I am not mistaken, isn't it usually the moving parts that fail on a traditional hard drive?
/ Solid state drives not reliable #3
you'll find that it's the drive interface that's not completely compliant with the bios. That's what we found a number of years ago when they first came out. Seems to be a common thing with the sst drives. We spent allot of money on testing hardware that got shelved. Surprised it hasn't improved since then though.
/ Solid state drives not reliable #4
Alan, I think Tim is spot-on. As with any new technology, the software bugs are there to "byte" you in the butt. Using a drive from a major supplier like Intel is probably the best cure to insure complete compatibility. You can be pretty sure that Dell and Intel test each others hardware/firmware/software for compatibility.
BTW: Just noticed that the Crucial M4 series has a MTBF of 1.2 million hours vs the industry standard of 1.5 million hours. I know that's wacky when you start counting millions of hours, but reduced numbers might also represent cooling or low level silicon issues in their construction.
Yea that is a point, unforutnately the first 2 failed about 1,999,800 hours too early. These are in fact Crucial M4 drives and they were about $400 each. We are replacing with Intel drives as they go out. I am actually now more concerned that the Symantec system restore software just flat won't work for us. Gonna try Acronis instead. Every time we have tried restoring from Symantec the drive won't boot and there is a "bootmgr.ini missing" error that we have not been able to correct.
/ Solid state drives not reliable #7
Did you mean 1,199,800 hours too early? 1.2 million is 1,200,000. I hate it when I have to correct an accountant.;):laughing:
Thanks for the correction. Unfortunately most accountants are terrible with figures......unless we have a calculator handy.......
Something to add to this discussion....I got 8 computers from Dell - 5 came with basic traditional 7200 RPM SATA hard drives (because you can't get Dell Optiplex computers without drives). We pulled those 5 out and replaced with Crucial M4 SSDs purchased from another source. Those 5 are for power users (myself included) and also have I7-3700 processors and 16GB of RAM. We also got 3 with only 8GM of RAM and Hybrid drives (have a built in cache that sort of acts like an SSD).
In the process of restoring from images I have had a chance to compare the speeds. Frankly the hybrids are surprisingly fast and nearly as fast as the SSDs. The traditional hard drives are extremely slow by comparison to either the the SSDs or the hybrids. If we have any more trouble with the SSDs the hybrids are the way to go, assuming they turn out to be reliable. So far so good. Just talking about boot time, my desktop in its current configuration takes about 30 seconds to boot and once the login screen comes up it is like 3 seconds after logging in to the domain. The same exact system setup restored to a traditional hard drive (which i am holding in case of SSD failure) takes about 2:45 to boot. The hybrids I haven't timed but seem not that much different from the boot time of the SSDs. These are all configured about the same, with the same applications installed.
/ Solid state drives not reliable #10
Interestiing. The SSD on my main system (Crucial m4 256GB) has worked flawlessly. At the same time, the other HDs (2x2TB 7200 internal & 2x2TB 7200 hot-swaps) have also not had any problem. So, hard to say in my case any one is more reliable than the others. I do notice a clear edge in startup time compared to the other PCs here. But given it only starts once a day, not that big a deal.
/ Solid state drives not reliable #11
I talked to my SIL yesterday about his SSDs. He said they were all Intel and had no failures, but exactly as you suggested, he said they were only slightly faster than 10,000 rpm hybrid drives. He felt the future was going to be the hybrids just as you said.
/ Solid state drives not reliable #12
I've been using SSDs for a couple years now in my work machine. No problems. We switched to recover some of the speed lost to encryption software.
One thing about SSDs, do not defrag them.
I turned off defrag on the SSDs, and the intel has a "trim" utility that runs automatically once a week. So far so good on the intels. Tried out Symantec System Recovery 2013 Desktop Edition and had a successful restore. So we now have all 10 computers backing using the new version, to an NAS drive. Right now we have 3 Crucials and 2 Intel SSDs in service, and 3 hybrids. So far 2 Crucial failures, no failures on the 2 Intels (but its only been a couple of months). Both are very fast, but like I say the hybrids are pretty dang fast too.
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63688)
2019 Cadillac XTS...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
