Sold on Seafoam
/ Sold on Seafoam #82
You take the cap off the seafoam can fill with
seafoam then pour in oil. I don't measure it.
It works for me!
willy
/ Sold on Seafoam #85
The seafoam cap
willy
/ Sold on Seafoam #86
That's less than a glug for sure.
I use 1 glug for every gallon of gas for maintenance
/ Sold on Seafoam #89
I suggest you watch 'Taryl Fixes All fuel additive video. Sea Foam ain't worth a crap. Very interesting YT viedo. Startron is even worse.
/ Sold on Seafoam #90
You are supposed to clean the spark arrestor regularly. Wire brush and a 30 second job.
That's funny, I had a stihl 044 and a 051. The 051 that I bought in the 70's and the 044 I bought mid 80's and all both of them ate was reg. pump gas and the stihl brand oil and neither one of them ever had the screen cleaned. The only thing I ever did to them was to keep the air filter clean, change a spark plug every year or so, and of course replaced chains and bars when needed, a oil cap or two and a few other related parts that normally wear out in the chain an bar area. Both would be still running if it hadn't been for the fire that burned my building down. Oh and I always mixed my gas 40:1 or i of their bottles of oil to 2 gallons of gas. Both of them preformed as good as they did when they were new.
/ Sold on Seafoam #91
He he he..............
/ Sold on Seafoam #92
In his test, the ONLY one that worked was VP syn fuel and he used new engines provided by Ariens so all the engines were new and not run. Everything else, the bowls were loaded with gunk on ethanol fuel. Very good test. Seafoam was the worst btw, Startron was second. The Marine Stabil started but still had some gunk in the bowl.
I'll stick with Trufuel for my ocasional use power equipment like chain saws and weed trimmers. It ain't cheap but neither is a new carb.
One thing about Taryl is, other than his wacky humor, he's always right. I subscribe to his YT channel and have for a long time.
Most wouldn't even start at all after a year sitting.
Was amazing how much crap was in the bowls. Gunk and rust from the water in the e-gas.
Obvious to me that Startron and Seafoam is nothing but junk.
/ Sold on Seafoam #94
This was a pretty timely post for me. I just picked up a bottle of Seafoam and I put a glug in all of my 2 and 4 stroke engines---dirtbike, chain saws (3), leaf blower, brush cutter, rototiller, splitter, pressure washer and my Kubota. I was having all kinds of trouble a few years back with the Kohler engine on my splitter. I had been in touch with Kohler several times and the tech recommended Seafoam. That engine puked after about a year and they covered it under warranty. About another year later, the replacement engine took a crap and was out of warranty by then (2 engines in a little over 2 years), so I just picked up a Predator at HF and it's been pretty flawless, especially compared to the Kohlers. I hadn't started the Predator in 4 months but it's that time again and this week I went out and gave that Predator a tug and she kicked off on the 1st pull. I'm running 90 octane non-ethanol with a splash of seafoam. To get away from the ethanol issues, I was running avgas 100, but I wondered if the lead wasn't causing some issues. When the 1st Kohler crapped out, a valve stuck. The 90 octane non-ethanol is a lot cheaper and I probably don't need the lead in these engines that weren't designed to run it. Kohler didn't think it was an issue in the 1st engine's failure but who knows…
/ Sold on Seafoam #96
I'm guessing your Kohler wasn't made in China. We had a Kohler on an old Simplicity L & G tractor and it sure mowed a lot of grass and blew a lot of snow. I had these engines on Craigslist for 40 bucks, just hoping someone wanted a project but no takers.
/ Sold on Seafoam #99
I’ve seen it. My experience, nor thousands of others, doesn’t necessarily correlate with his results. But, I don’t use SeaFoam as a stabilizer either, so his little experiment doesn’t really apply to the other things SeaFoam does.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2007 Chevrolet W5500 20FT Dovetail Flatbed Truck (A59230)
2007 Chevrolet...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
