You are very right. If I was completely off-grid, I would use even less electricity than I use now. I have a neighbor who is completely off-grid, just because he didn't want to pay the power company fee for running lines ($85,000). He uses very little electricity. Heat is solar hydronic with about 70 cubic yards of concrete thermal mass. A separate system supplies his domestic hot water. It's a thermal siphon system that does not require electricity. For AC he chills the hydronic system at night and with an evaporative cooler in daytime. Domestic water is a PV 48 volt piston pump to a water tower. Domestic electricity is a PV system and 3000w inverter, which is far more capacity than he uses.
It's a luxury to design for energy efficiency from the beginning of construction. His system had big up-front costs, but he has no utility bills.
My house is 45 years old, and I had to retrofit for energy efficiency. There were no energy codes when it was built. Thanks to my own timber, I have no shortage of firewood. There is more wood falling off of trees than I need for domestic heat. 20 years of remodeling have upgraded the insulation, windows, doors, and we just ponied up for cellular blinds on the south side of the house to reinforce the low-E U.36 windows. I installed a 2500 gallon spun poly cistern to compensate for low well flow in the late summer, and put it above the level of the house. Bingo, gravity feed water. You are right about the solar hot water. 50% of the energy costs of a typical household goes to nothing but heating water. I have just been too lazy to deal with it.
I don't get much concerned about external inputs. When things get tough, externals may get expensive but they will be available. The trick is to reduce the amount you need. The advantage of conservation is that it pays even if the lights stay on.
