Solar Battery Charger... ?
/ Solar Battery Charger... ? #1
Dave___in___CT
West-Central CT
Kubota L3130, LA723 Loader, BH90 Backhoe, Curtis Cab, || '82 Gravely 8199KT garden tractor
Hi...
What's your experience and opinion using a solar battery charger to maintain a tractor's battery strength/condition ?
Brands ? Models ? Size ? Cost ? Effectiveness ? Heat, cold, weather affects ?
I'm looking into a solar charger/maintainer as a solution to maintain the 12 volt battery strength/condition on my compact utility tractor when it will be left for 1 or 2 or 3 or 4 weeks without running it... There's no electric power nearby...
Here's one that seems pretty good... VDC Electronic's BatteryMINDer Solar Maintenance/Charger 12 Volt 5 watt... model SC005
Retailer...
Street price is ~$100...
Thanks...
Dave...
/ Solar Battery Charger... ? #2
I keep a solar battery charger on my 12v 1954 Ford NAA, 12v 1966 IH cub, and my 12v 1997 NH 1920... have been for a few months now.
I got 'cheapy' ones from harbor freight tools.. they were 19.99, but on sale for 9.99... they claim charge at 125 ma, in direct sunlight, with a no=load voltage near 20v.
Mine have been working great. I only get to drive my tractors on the weekend.. and then.. usually only one.. as i have 5 tractors.. etc.. so usually it is well.. 5 weeks between running each one.. I used the NAA, and the cub this weekend. Normall the ammeter shows a good charge after starting, to make up for the used power.. but after charging in the sun for a few weeks, it started up fast.. and ammeter didn't show anything more than ignition draw till I use dthe lights.. etc. Same with cub.. zoomed to life very quickly.
I've been contemplating getting 6v chargers for my 8n and JD 'B'.. as they are still 6v... Tsc has both 6v and 12v chargers for something like 29.99 / 39.99... can't justify that price yett though, as I do have electric and a booster/charger in the barn if I need it.
Soundguy
/ Solar Battery Charger... ? #3
I've got an ICP Global Pro 115 solar panel connected to an ICP Global 7 amp charge controller that I use to maintain the battery on my Jeep. I only use the Jeep occasionally and the clock, stereo, car alarm etc. is a fairly heavy constant draw so a charge maintainer of some sort is a neccessity if I'm not going to drive it for about 2 weeks. I've found that the solar charger is only really useful for about 9 months out of the year, the other 3 months are too cloudy and the days are too short for it to keep up with the rate of discharge. I use one of the permanent mount 120v plug in style charge maintainers for the dark cloudy months.
As for installation:
I made a saw horse type wooden stand to mount the panel and have it facing due south. The saw horse sits outside the Cover-it shelter that I use for Jeep storage. I ran the two wires from the solar panel to a cheap Radio Shack 12v DC meter and then from the meter to the 7 amp charge controller. I wired a standard flat four male trailer harness plug to the two wires that connect from the charge controller to the battery in the Jeep. I then wired a standard flat four female trailer plug directly to the battery, be sure that you keep your polarity correct or the magic smoke might be released from something. I also wired a male flat four connector to the battery leads for the 120v charge controll unit. The trailer connects give me a simple sturdy quick connect system.
I bought the solar stuff from Cabela's web site, just do a search on "solar panels". The approximate cost for the setup I have is about $150.00
I'll post pics some time this weekend, it's the only time I'm home while there's daylight this time of year.
boxman
/ Solar Battery Charger... ? #4
Yikes.. that must be some draw... I use lots of battery/solar fence chargers.. and they claim to work for something like 20 days of dark / overcast conditions.. and these are 4 and 6v units... Even cheapy harbor freight 12v chargers can kick out 125ma....that's an 1/8 of an amp..if your draw is that high on your jeep.. that is phenominal..... might want to check that..
Soundguy
/ Solar Battery Charger... ? #5
any pictures of guages and setup? I wanted to make a volt/amp adapter to hook in line with some of my chargers and see what is actualy going on. thanks
/ Solar Battery Charger... ? #6
I have a siemens 50 watt solar panel on the roof of my Lance truck camper with a 7 amp charge controller built below the sink.
It keeps my group 31 deep cycle charged when the camper is idle as well as in the woods.
The panel is completely weatherproof. They aren't cheap, however. About $500.00.
/ Solar Battery Charger... ? #7
Re: Pics
This is the panel and saw horse stand.
/ Solar Battery Charger... ? #8
Re: Pics
This is the charge controller and meter.
/ Solar Battery Charger... ? #9
Re: Pics
This is a close up of the meter.
/ Solar Battery Charger... ? #10
Re: Pics
This is my winter time charger, it's one of the permanent mount 120v plug in units that I've mounted on a piece of plywood instead of on the fenderwell as the manufacturer intends.
/ Solar Battery Charger... ? #11
Re: Pics
This is a close up of the flat four trailer harness.
/ Solar Battery Charger... ? #12
Re: Pics
And now for the (lawn)tractor content.
/ Solar Battery Charger... ? #13
Re: Pics
Just one more pic of the solar panel.
/ Solar Battery Charger... ? #14
Re: Solar Battery Charger...
I think it would have been a good idea for you to KEEP the original Subject of this topic.
The Subject PICS when viewing the list of posts tells me nothing.
/ Solar Battery Charger... ? #15
Gatorboy:
Cut the fellow some slack here. He DID change the subject line, but you changed it back.
/ Solar Battery Charger... ? #16
Thanks for the tip Gatorboy, I'm still learning all of the quirks of this WebBBS interface and had no idea that flat mode was the default view...and the subjet PICS at least told you there were pics and you looked /forums/images/graemlins/laugh.gif
/ Solar Battery Charger... ? #17
<font color="blue"> ( I'm still learning all of the quirks of this WebBBS interface and had no idea that flat mode was the default view )</font>
Normally (in non-flat BBS), changing subject lines is encouraged to relay the current conversation within a conversation, but here it is somewhat frowned upon for the reason you stated.
Regardless, thanks for posting the pictures. /forums/images/graemlins/cool.gif
/ Solar Battery Charger... ? #18
I've a little solar panel that charges up the 12v light that I bought from countryhomeproducts (web site by this name), the folks that make the DR mowers/trimmers. It works great. The solar light, incl. the panel was about $119.
TSC has 12v solar panels for around $130 that are designed to charge 12v batteries that are used to run their gate openers/closers. I've thought about buying one of these to charge the batteries I use in my big garden for electric fencing and for my 12v irrigation pump. May yet, if we finally get another dry year. Didn't have to run the pump last year, and the fence runs about a month on each charge.
Ralph
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
Brady 512 Feed Wagon (A66408)
Brady 512 Feed...
2008 Case IH JX80 Tractor and Loader (A66285)
2008 Case IH JX80...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
RAYTREE RMPP680 HYD POST POUNDER (A64277)
RAYTREE RMPP680...
