Soil Separator
/ Soil Separator #1
JMA375HH
Soldotna Alaska
NH TC33DA
I needed something too separate all my top soil from all the roots and wood from clearing land. and so I built this and and it works pretty good. will add a shacker motor next season.
/ Soil Separator
I welded on too bucket hooks with a 140 110v mig I was only able too get two of them due to last ones in stock. and had to make many passes with the Lincon 140. I did this to see what kind of penitration the littel 110 machine would get. and was not surprised to see it was not a hole lot. I won"t be hanging or pulling much till i can reweld with my 220v Miller. 110v migs are great for small stuff.
/ Soil Separator #3
Do you drag the separator along the ground as you seive the stuff out? Is that a hitch on the front?
do the debris just fall off the face pretty well, or do you have to manually clean them off much?
I think I am going to add my Vibratory compactor into the mix to help shake it.
I have it already, but even if I did not, the unit is only $500 from HF and has several other uses as well.
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2011 GORILLA BUILT MANIFOLD TRAILER (A67714)
2011 GORILLA BUILT...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
AIR COMPRESSOR 3-PHASE (A67714)
AIR COMPRESSOR...
SHOP BUILT  PRESSURE WASHER TRAILER (A67714)
SHOP BUILT...
