soft shackle users?
/ soft shackle users?
Most tow ropes you get today don't have hooks. The nylon shackles allow you to attach to whatever without a hook. I thought I'd get a couple of them to put in our 6x6.
/ soft shackle users? #24
I'm curious why? Is it concern over the strength? I admit that it takes some getting used how strong they are. Just looking that them you would think "no way". But they are generally SIGNIFICANTLY STRONGER that similarly sized chain or steel shackles. Just by way of example, 1/2" G43 chain is rated for 4.5MT, and a 1/2" Crosby shackle is rated for 3.3MT. On the other hand, a 1/2" soft shackle has a breaking strength of 20MT. Their strength is very deceptive, and I think is why people are slow to embrace them.
Chain is working load limit,. A third or fourth of break strength.
The rating on the cloth is the break point.
/ soft shackle users? #25
I keep some in my truck. Had to use a few times. I like em.
I try to use my steel clevises as much as possible but they can come in handy because of the flexibility
/ soft shackle users? #26
I'm interested in them as well; an eventual purchase, but one that is worth looking into in the interim.
/ soft shackle users? #28
"Rope retention pulley." That's a new one! Someone has taken one of the oldest bits or bobs in standing rigging, given a new name, and found a new way to sell it. They used to call them deadeyes, more recently lead rings, but "rope retention pulley" is the most creative name of all for this simple alloy ring.
/ soft shackle users? #29
Looking at the Bubba rope site at the shackles...I'm not thrilled about the light duty ones. They use a sliding plastic collar to perform the choke vs the normal way of the rope through the rope design. It is fine until that plastic collar snaps. Their HD ones are manufactured with the rope thru rope design.
/ soft shackle users? #31
Honestly, you guys should just make your own. Single braid is incredibly easy to splice and to create shackles of this type. If you get into double braid, dyneema or vectran with a more durable outer sheath as I had mentioned early in this thread, then things get a little more complicated. But all those I've seen pictured so far are simple single braid, easy. I don't even use a fid, I just use a coat hanger bent in half and threaded thru an old drumstick as a handle.
/ soft shackle users? #32
Correct, and with those same safety factors the soft shackle is still as strong or stronger.
Would you like to make us some?
/ soft shackle users? #34
If you want to see them in use, look at the Youtube channels for Matt's Off-Road Recovery, Fab Rats, or Trail Mater. They use them for off road recoveries, along with kinetic recovery ropes. They also use synthetic rope for their winches.
Me personally, I use poly ropes for everything. Only exception is choking and dragging logs.
/ soft shackle users? #36
I honestly only use chains to tie down the mini on the trailer.
I keep 4 different straps in the truck. I do have steel clevises for certain applications but mainly use rope.
Winch cables are rope also.
If something breaks, I don't want steel coming back at me with all that energy.
I appreciate the stretch you can get with some poly or nylon straps. Seems that allows less chance of them coming loose.
/ soft shackle users? #38
I gotta try one of those kinetic straps. We use straps alot. We do alot of off roading, mainly sand dunes.
For soft shackles, I use rhino 1/2". They say breaking point is 46k lbs. My biggest strap is 30k rated.
Had a straps that was rated for 100k but it was "lost" when the moving company moved our household goods from AK to MI.
Was at a rural wedding about 3 years ago. All the guests parked in a field and it was a wet time of year. Think I pulled out about 30 vehicles using a 20k strap and soft shackles. You could basically watch a Ford 3/4 ton sink during the ceremony.
/ soft shackle users? #39
You have to be very careful, they contain so much energy, strap points are very important, and remember to never use a hitch ball as a strap point.
also realize you only get about 4 -6 pulls before the straps need to take a break...
/ soft shackle users? #40
I use one of those hitches that have a clevis. I don't use a ball hitch to to pull some one. Luckily on that day it was mostly cars where no serious stress was needed, just some pressure to get them moving.
That 3/4 ton was another story. He was almost to the hubs with street tires.
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
30" X 12' ADS DRAINAGE PIPE (A64281)
30" X 12' ADS...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
MAMMOTH AIR CONDITION PACKAGE UNIT (A64281)
MAMMOTH AIR...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
