So I did a thing... Agria 8900D
   / So I did a thing... Agria 8900D #191
This is a terrible thread; it cost me most of the day. I should have been working on my tractor, and instead I was reading 19 pages, gooning out on pictures and video...
I thought my tractor had been badly treated (never greased, repair attempts that caused damage, etc.), but whoever perpetrated those crimes on that poor Agria really should be reported for cruelty to machines.
Great coverage of an amazing save, bringing the dead back to life.
I hope you can come up with a way to live with the steering, it seems a terrible shame to let all that work walk away for one little problem.
Ok, maybe not so little.
   / So I did a thing... Agria 8900D #192
Just curious if any of Antonio Carraro, Goldoni, Pasquali or Ferrari etc. same style tractor models have power steering and if those ideas or parts could be adapted?
This is expensive, won't help contain leaks and may not deflect pinhole leaks but may help avoid impact damage. It may also cause wear damage when the hose moves with the flexing though, you may want to consider if the cost of protecting it outweighs the cost of simply replacing the hose more often.
Looks like there's also "hydraulic hose wrap" which may cause less scuffing to the paint.
I suppose the ultimate would be a swiveled hydraulic coupler mounted directly over the axis of articulation, then you could use a hard line?
It really needs the hose. There is a lot going on as not only it steers left/right, but it also pivots/tilts left and right, just like a front axle on a conventional tractor, but in this case, the entire front half twists in relation to the back half. So the hose ends up having to move quite a bit. They do made so it runs as little hose as possible, the rest is hard lines.
Sorry Mark!!!
This poor thing has had indeed a very rough life. I mean, it was literally about to be broken in half. I don't even understand how they managed to use it that way. Must be so frustrating having to turn at least 1 full turn before it actually started steering, plus the front half just flopping around like crazy.
I'm just glad it didn't have any broken gears or damaged/stripped splined shafts. Having to buy or have those made would just blow the budget in every way possible.
As I've been getting the feel for the tractor, I'm doing better with the steering situation. I now know work with it, instead against it. As you start turning the steering wheel, there is this sweet spot as it starts turning that will help you steer and not being too hard on the arms.
I think I'll still put the steering wheel from my backhoe on the Agria and move the one from the Agria to the backhoe. It bigger, so it should make it easier.
Not gonna say I won't send it down the road if another good project pops up at a good price, specially something with power steering, but for now, I'm keeping it.
I want to make some handrails for it as well.
They all have different parts made for their own models. Could be adapted for sure but it's also big money just to get the parts. Even Agria had the same model with power steering coming a couple years after mine.
It's the Agria 8900DE instead of just the "D" like mine. Had a tandem pump mounted on the engine, so the steering has its dedicated pump, a steering valve instead a steering box and a cylinder mounted just below it.
Main reason for me to not do anything about it so far, is cost. I really don't want to throw big money at it as it's not my main tractor. I only use occasionally, I can live with it as is.
How does the steering work?
On mine, there is this really big and heavy duty steering box (pic #1) mounted in the front half of the tractor. Inside, it's a worm drive and a big gear (pic #2). Then, out the output shaft where the pitman arm mounts. Two steering ball joints, welded back to back, connect the pitman arm to the rear half of the tractor. Hopefully the picture #3 makes it more clear than my explanation.
   / So I did a thing... Agria 8900D #195
Good solid massive mechanical stuff; maybe not so supple, but it's pretty much indestructible.
A bigger wheel should help, as long as there's room for it.
Americans might not appreciate the very high cost of used parts in Portugal; I'm continuously amused and disappointed at the prices demanded for things that could as easily be sent to the scrap yard.
Even at the scrap yard, they demand silly prices!
Of course it's worse for me, both as a foreigner and my location in the south where there is little industry. The old guys around here would rather watch an old machine rust into the ground than sell it 'cheap'.
I bought a used car engine from the Netherlands; it was cheaper to ship it from there (1,500 miles) than buy the same engine here.
Tell me about it! There are so many cases like that all over the country. Real cool cars, trucks, tractors, machines, etc with lots of value just rusting away because the owners are too proud or stubborn on the prices.
Then, another thing that happens a lot is when the owners die, during the the inheritance sharing process, the titles and paper work for these vehicles are lost and then the vehicles are pretty much worthless without the paper work and pretty much impossible to get paperwork done.
I've been eyeing this very cool Same Puledro for years now. 2 cylinder air cooled Same diesel, one of the very first Same 4x4 tractors. The guy is asking 3500€. It's a crazy amount of money for it and that's why it's been sitting there for sale for years now.
I would really like to get my hands on it. I like those old tractor with round/curved hoods.
A better look at it:
Also, have you been getting any rain down there?
   / So I did a thing... Agria 8900D #197
I agree, those older round ones look much better than the 80's square hood like I have.
My wife says I need to fix the "face", it looks all beat up!
It's a tractor I tell her... it happens.
We've had 60mm of rain so far. Not much but a lot better than nothing.
It's been raining almost non stop here for the past week or so. Had a day or two of mostly clear skies that allowed me to take a big tree down and haul the wood with the Agria.
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A54865)
New/Unused 7ft...
2013 Chevrolet Equinox LTZ AWD SUV (A55758)
2013 Chevrolet...
Decorative Metal 5-Point Star (A55758)
Decorative Metal...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
