SnowPlow test #1
   / SnowPlow test #1 #11
I'm not sure that material was made to be a squeegee. It is the same material one uses for a deflector that is on the top of the plow to stop the snow from coming over the blade. I believe it is the same material they use for making mud flaps for tractor trailer trucks. :) The Gotcha Man
   / SnowPlow test #1 #12
jmfox said:
That's what I need to turn my 4-in-1 plow blade into a snow machine, a bolt on squeegie strip to replace the metal blade. Anybody know where I can find one?
jmf
if there is a quarry or sand and gravel operation near you find out what they do with their old conveyer belting. The stuff is bullet proof for this application. it is usually 36 or 48 inches wide and about a 1/2 inch thick and can be cut into strips.
have laced to many together working in the plants.
the problem you might find is the volume of material as most of the stuff we would replace was in 100 ft rolls
Don
   / SnowPlow test #1
No it wasn't, it was made to be conveyor belts, but it just so happens it works very well as a squeegie. It has reinforcing cords woven through it which gives it it's strength.
My buddy plows snow professionally and he equips his plows with conveyor belting material from a local rubber wholesaler, has been doing it for years.
That is who gave me the idea.
He uses the real thick stuff, about 3/4" thick, but then again, he is clearing roads and parking lots.
   / SnowPlow test #1 #14
That's not a snow plow - it's a Zamboni
Beautiful job!
   / SnowPlow test #1 #16
johnray13 said:
How much was it? That is something I would consider. Any idea how long it last before it wears away?
I got mine from JD and it was on my 355D for 6 years and still looked great.
   / SnowPlow test #1 #17
SkunkWerX said:
AFTER
It did snow some more, adding a couple more inches, so the plow got another quick test right before dinner. it's still snowing a little, due to stop by 8pm, so maybe I'll do a quick run after it stops, just another excuse! ;)
I plowed 4'' of snow off my driveway this evening with a front blade just like yours.
Worked great.
Was the first time I plowed snow with it.
I got it about a month ago for my BX1500.
   / SnowPlow test #1 #18
So does truck bed mats.
   / SnowPlow test #1 #19
SkunkWerX said:
It even allowed me to scrape our cobblestone/paver front sidewalk, which I would never do with just a steel blade, for fear I'd snag pavers and rip them up. :eek: .
Skunk--This is the normal course of things here--Whole huge parking lots are made of those concrete pavers and hence all snow plows here have the rubber edge. I made a rear blade for clearing snow and I will buy a rubber strip from this company. PHU KRIS Warszawa - gumy do p³ugów œnie¿nych
I do not imagine that many can read it, but at the bottom there are pics of all kinds and sizes of plows.
Mike
What the site does not allow Polish characters?!!! :D Actually so often I start wishing that we could get here what is available in the States, but this is one area that I think that we have met the Stateside fare. :)
   / SnowPlow test #1
LBrown, I can see where truck bed mats would work, as well.
Anything flexible, yet tough enough not to abrade away too quickly.
MJP, hadn't thought about it, but yes, the "old world" is full of cobblestones, and pavers/stone with a lot of seams, a real nice place to get use of a flexible edge.
The other thing that was brought to my attention was the use of Non-Marking material. It's worth a quick test somewhere, to make sure the rubber isn't going to leave a black skidmark down the middle of your white concrete driveway or your decorative colored cobblestones.
On the asphalt pavement I wasn't very concerned.
I used a steel edge for about 20 years, worked OK, but now that I have seen what a rubber edge will do, I will only go back to the steel if I'm trying to tackle packed in snow and ice.
My key to effiective snow removal on pavement is NOT to drive on it, plow first.
Today, coming home from work, I noticed some of the local driveways that had not gotten a lot of effort, well some had gotten NO effort, and had been driven on and mashed down. They are now covered in icy frozen solid tiretracks. tsk tsk tsk. Good way to fall and get a back injury for life.
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
New 4-17.5 Forerunner Skidloader Tires (A50774)
New 4-17.5...
